Farmland Irrigation Remote Monitoring System Based on Configuration Software and Multiple Serial Port Communication
The design and implemental plan of the farmland irrigation remote monitoring system with variable frequency and constant pressure based Configuration Software and multiple serial port communication were introduced. The implementation of the communication between inverter, PLC, ADAM and KingView was studied. The data acquisition and monitoring scheme were analyzed. The hardware and software design of system were discussed in detail. It had been successfully applied to farmland irrigation, and the effects of automation and energy conservation had been as good as expected.
