A New Method of Transductive SVM-Based Network Intrusion Detection
Based on the existing Transductive SVM and via introducing smooth function P($\triangle$,λ) to construct smooth cored unconstrained optimization problem, this article will build the optimization model accessible to degenerate solutions to generate an improved transductive SVM, introduce simulated annealing to degenerate the optimization problem, and apply such a Support Vector Classifier to generate a new method of network intrusion detection.
