Equilibrium, kinetic and thermodynamic studies on the biosorption of Cu(II) onto chestnut shell, Journal of Hazardous Materials, vol.174, issue.1-3, pp.137-143, 2010. ,
DOI : 10.1016/j.jhazmat.2009.09.027
Discrimination of moldy Chinese chestnut based on artificial neural network and near infrared spectra, Transactions of CSAM, vol.40, pp.109-112, 2009. ,
Effect of temperature variation on the visible and near infrared spectra of wine and the consequences on the partial least square calibrations developed to measure chemical composition, Analytica Chimica Acta, vol.588, issue.2, pp.224-230, 2007. ,
DOI : 10.1016/j.aca.2007.01.079
Classification of tomatoes with different genotypes by visible and short-wave near-infrared spectroscopy with least-squares support vector machines and other chemometrics, Journal of Food Engineering, vol.94, issue.1, pp.34-39, 2009. ,
DOI : 10.1016/j.jfoodeng.2009.02.023
Comparison of Combination and First Overtone Spectral Regions for Near-Infrared Calibration Models for Glucose and Other Biomolecules in Aqueous Solutions, Analytical Chemistry, vol.76, issue.18, pp.5405-5413, 2004. ,
DOI : 10.1021/ac0498056
NIR calibration in non-linear systems: different PLS approaches and artificial neural networks, Chemometrics and Intelligent Laboratory Systems, vol.50, issue.1 ,
DOI : 10.1016/S0169-7439(99)00048-9
Classification of Wines Produced in Specific Regions by UV???Visible Spectroscopy Combined with Support Vector Machines, Journal of Agricultural and Food Chemistry, vol.55, issue.17, pp.6842-6849, 2007. ,
DOI : 10.1021/jf070634q
An ensemble of Monte Carlo uninformative variable elimination for wavelength selection, Analytica Chimica Acta, vol.612, issue.2, pp.121-125, 2008. ,
DOI : 10.1016/j.aca.2008.02.032
Non-destructive discrimination of Chinese bayberry varieties using Vis/NIR spectroscopy, Journal of Food Engineering, vol.81, issue.2, pp.357-363, 2007. ,
DOI : 10.1016/j.jfoodeng.2006.10.033
Classification of brands of instant noodles using Vis/NIR spectroscopy and chemometrics, Food Research International, vol.41, issue.5, pp.562-567, 2008. ,
DOI : 10.1016/j.foodres.2008.03.011
Classification of Tempranillo wines according to geographic origin: Combination of mass spectrometry based electronic nose and chemometrics, Analytica Chimica Acta, vol.660, issue.1-2, pp.227-231, 2010. ,
DOI : 10.1016/j.aca.2009.09.030
Development and validation of near infrared microscopy spectral libraries of ingredients in animal feed as a first step to adopting traceability and authenticity as guarantors of food safety, Food Chemistry, vol.121, issue.3, pp.871-877, 2010. ,
DOI : 10.1016/j.foodchem.2009.10.072
Feature reduction by Fourier transform in pattern recognition of NIR data, Analytica Chimica Acta, vol.331, issue.1-2, pp.75-83, 1996. ,
DOI : 10.1016/0003-2670(96)00195-X
Application of Fourier transform to multivariate calibration of near-infrared data, Analytica Chimica Acta, vol.364, issue.1-3, pp.253-263, 1998. ,
DOI : 10.1016/S0003-2670(98)00120-2
Near-infrared spectral detection of soil moisture based on feature extraction of FFT. Transactions of CSAM, pp.64-67, 2009. ,
A BP-neural network predictor model for plastic injection molding process, Journal of Materials Processing Technology, vol.103, issue.3, pp.411-416, 2000. ,
DOI : 10.1016/S0924-0136(00)00498-2
Flank wear prediction in drilling using back propagation neural network and radial basis function network, Applied Soft Computing, vol.8, issue.2, pp.858-871, 2007. ,
DOI : 10.1016/j.asoc.2007.07.003
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.135.4096
Application of the Back Propagation Neural Network Algorithm with Monotonicity Constraints for Two-Group Classification Problems, Decision Sciences, vol.20, issue.1, pp.60-75, 2007. ,
DOI : 10.1109/72.80210
A simulated-annealing-based approach for simultaneous parameter optimization and feature selection of back-propagation networks, Expert Systems with Applications, vol.34, issue.2, pp.1491-1499, 2008. ,
DOI : 10.1016/j.eswa.2007.01.014
Modeling leaching behavior of solidified wastes using back-propagation neural networks, Ecotoxicology and Environmental Safety, vol.72, issue.3, pp.843-850, 2009. ,
DOI : 10.1016/j.ecoenv.2007.10.019
Performance of the Levenberg???Marquardt neural network training method in electronic nose applications, Sensors and Actuators B: Chemical, vol.110, issue.1, pp.13-22, 2005. ,
DOI : 10.1016/j.snb.2005.01.008
Handbook of Near-Infrared Analysis, 2007. ,
