Effect of cooking and cooling method on the processing times, mass losses and bacterial condition of large meat join ,
Effect of rapid and conventional cooling methods on the quality of cooked ham joints, Meat Science, vol.56, issue.3, pp.271-277, 2000. ,
DOI : 10.1016/S0309-1740(00)00052-8
Modelling vacuum cooling process of cooked meat?part 1: 5. tion, pp.862-871, 2002. ,
New model for frost growth rate. International Journal of 10. sting 11. hermal conductivity of frost while forming 12. to slip -flow, 13, Engineering 14. ges in beef burgers and mashed, 1998. ,
Modelling vacuum cooling process of cooked meat???part 2: mass and heat transfer of cooked meat under vacuum pressure, International Journal of Refrigeration, vol.25, issue.7 ,
DOI : 10.1016/S0140-7007(01)00095-0
Effect of operating conditions of a vacuum cooler on cooling performance for large cooked meat joints, Journal of Food Engineering, vol.61, issue.2, pp.231-240, 2004. ,
DOI : 10.1016/S0260-8774(03)00095-5
Modeling frost characteristics on heat exchanger fins: Parts I, Numerical Model, ASHRAE Transactions, pp.357-367, 2000. ,
Performance of finned-tube heat exchangers under frosting conditions: I. Simulation model, International Journal of Refrigeration, vol.16, issue.3, pp.175-180, 1993. ,
DOI : 10.1016/0140-7007(93)90045-A
An investigation of the t on a flat horizontal plate, ASHRAE Trans, vol.73, issue.2, pp.111-117, 1967. ,
The Graetz problem extended to slip-flow, International Journal of Heat and Mass Transfer, vol.40, issue.8, pp.1817-1823, 1997. ,
DOI : 10.1016/S0017-9310(96)00256-6
Thermal properties of foods, (E properties of foods, pp.49-87, 1986. ,
The influence of compositional chan potatoes on their temperatures following microwave heating and their thermal and dielectric properties ,
