A model separating leaf structural and physiological effects on carbon gain along light gradients for the shade-tolerant species Acer saccharum, Plant, Cell and Environment, vol.20, issue.7, pp.845-866, 1997. ,
DOI : 10.1046/j.1365-3040.1997.d01-133.x
Visible and near-infrared reflectance techniques for diagnosing plant physiological status, Trends in Plant Science, vol.3, issue.4, pp.151-156, 1998. ,
DOI : 10.1016/S1360-1385(98)01213-8
Utility of an image-based canopy reflectance modeling tool for remote estimation of LAI and leaf chlorophyll content at the field scale, Remote Sens. Environ, vol.113, pp.259-274, 2009. ,
Hyperspectral indices and model simulation for chlorophyll estimation in open-canopy tree crops, Remote Sensing of Environment, vol.90, issue.4, pp.463-476, 2004. ,
DOI : 10.1016/j.rse.2004.01.017
Leaf chlorophyll content retrieval from airborne hyperspectral remote sensing imagery, Remote Sens. Environ, vol.112, pp.3234-3247, 2008. ,
A Modeling Approach for Studying Forest Chlorophyll Content, Remote Sensing of Environment, vol.71, issue.2, pp.226-238, 2000. ,
DOI : 10.1016/S0034-4257(99)00089-9
Mapping leaf chlorophyll and leaf area index using inverse and forward canopy reflectance modeling and SPOT reflectance data, Remote Sens. Environ, vol.112, pp.186-202, 2008. ,
Monitoring the vernal advancements and retrogradation of natural vegetation, Final Report, pp.1-137, 1974. ,
Spectral Reflectance Changes Associated with Autumn Senescence of Aesculus hippocastanum L. and Acer platanoides L. Leaves. Spectral Features and Relation to Chlorophyll Estimation, Journal of Plant Physiology, vol.143, issue.3, pp.286-292, 1994. ,
DOI : 10.1016/S0176-1617(11)81633-0
Evaluation of Vegetation Indices and a Modified Simple Ratio for Boreal Applications, Canadian Journal of Remote Sensing, vol.17, issue.3, pp.229-242, 1996. ,
DOI : 10.1080/01431169408954343
Estimating Corn Leaf Chlorophyll Concentration from Leaf and Canopy Reflectance, Remote Sensing of Environment, vol.74, issue.2, pp.229-239, 2000. ,
DOI : 10.1016/S0034-4257(00)00113-9
URL : https://naldc.nal.usda.gov/naldc/download.xhtml?id=26536&content=PDF
Optimization of soil-adjusted vegetation indices, Remote Sensing of Environment, vol.55, issue.2, pp.95-107, 1996. ,
DOI : 10.1016/0034-4257(95)00186-7
Relationships between leaf pigment content and spectral reflectance across a wide range of species, leaf structures and developmental stages, Remote Sensing of Environment, vol.81, issue.2-3, pp.337-354, 2002. ,
DOI : 10.1016/S0034-4257(02)00010-X
Potentials and limits of vegetation indices for LAI and APAR assessment, Remote Sensing of Environment, vol.35, issue.2-3, pp.161-173, 1991. ,
DOI : 10.1016/0034-4257(91)90009-U
A soil-adjusted vegetation index (SAVI), Remote Sensing of Environment, vol.25, issue.3, pp.295-309, 1988. ,
DOI : 10.1016/0034-4257(88)90106-X
Estimating chlorophyll content from hyperspectral vegetation indices: Modeling and validation. agricultural and forest meteorology, pp.1230-1241, 2008. ,
Estimation of crop yield based on weight optimization combination and multi-temporal remote sensing data, Transactions of the CSAE, vol.25, issue.9, pp.137-142, 2009. ,
An iterative algorithm for optimal combination forecasting of non-negative weights. Systems Engineering Theory Methodology Application, pp.48-52, 1994. ,
Study of combination forecasting error information matrix, Journal of UEST of China, vol.21, issue.4, pp.448-454, 1992. ,
