Conference papers
An Inspection Method of Rice Milling Degree Based on Machine Vision and Gray-Gradient Co-occurrence Matrix
Abstract : A detection method of the rice milling degree was proposed based on machine vision with gray-gradient co-occurrence matrix. Using an experimental mill machine, different milling degree samples of rice were prepared. The rice kernel image of the different milling degree was get by a machine vision detecting system, then the texture features of the rice image were obtained by using gray-gradient co-occurrence matrix, at last the Fisher discriminate functions constructed using stepwise discriminate analysis were used to detect the milling degree of the rice samples. The testing results show that the average accuracy rate of the different milling degree detected using the method of 4 rice samples is 94.00%.
Document type :
Conference papers
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01559628
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, July 10, 2017 - 5:28:46 PM
Last modification on : Tuesday, April 5, 2022 - 9:02:02 PM
Long-term archiving on: : Wednesday, January 24, 2018 - 6:19:23 PM
File
978-3-642-18333-1_23_Chapter.p...
Identifiers
Citation
Peng Wan, Changjiang Long. An Inspection Method of Rice Milling Degree Based on Machine Vision and Gray-Gradient Co-occurrence Matrix. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.195-202, ⟨10.1007/978-3-642-18333-1_23⟩. ⟨hal-01559628⟩
Share
Metrics
Record views
79
Files downloads
235
