Report on Standardization (draft) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2017
Jack Bowers
Adeline Joffres
  • Fonction : Auteur
  • PersonId : 1188578
Antonis Litke
  • Fonction : Auteur
The present report reflects the second stage of the definition of the Standardisation Survival Kit (SSK) within Work Package 4 of the PARTHENOS project. On the basis of the various user scenarios presented in Deliverable 4.1, where each stage of the research process has been annotated according to the actual standards that are actually needed in order to fulfill the research task, we present here a systematic review of the activities that have to be carried out to provide support to researchers in using, but also contributing to, these standards.
D4.2 report on Standardization.pdf (3.42 Mo) Télécharger le fichier
hal-01560563 , version 1 (11-07-2017)
Paternité
  • HAL Id : hal-01560563 , version 1
Laurent Romary, Piotr Banski, Jack Bowers, Emiliano Degl’innocenti, Matej Ďurčo, et al.. Report on Standardization (draft). [Technical Report] Deliverable 4.2, Inria. 2017. ⟨hal-01560563⟩
1071 Consultations
697 Téléchargements
