New interface
Journal articles
An extended model of vesicle fusion at the plasma membrane to estimate protein lateral diffusion from TIRF microscopy images
Abstract : AbstractBackgroundCharacterizing membrane dynamics is a key issue to understand cell exchanges with the extra-cellular medium. Total internal reflection fluorescence microscopy (TIRFM) is well suited to focus on the late steps of exocytosis at the plasma membrane. However, it is still a challenging task to quantify (lateral) diffusion and estimate local dynamics of proteins.ResultsA new model was introduced to represent the behavior of cargo transmembrane proteins during the vesicle fusion to the plasma membrane at the end of the exocytosis process. Two biophysical parameters, the diffusion coefficient and the release rate parameter, are automatically estimated from TIRFM image sequences, to account for both the lateral diffusion of molecules at the membrane and the continuous release of the proteins from the vesicle to the plasma membrane. Quantitative evaluation on 300 realistic computer-generated image sequences demonstrated the efficiency and accuracy of the method. The application of our method on 16 real TIRFM image sequences additionally revealed differences in the dynamic behavior of Transferrin Receptor (TfR) and Langerin proteins.ConclusionAn automated method has been designed to simultaneously estimate the diffusion coefficient and the release rate for each individual vesicle fusion event at the plasma membrane in TIRFM image sequences. It can be exploited for further deciphering cell membrane dynamics.
Document type :
Journal articles
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-01561310
Contributor : BMC BMC Connect in order to contact the contributor
Submitted on : Tuesday, August 1, 2017 - 7:05:31 AM
Last modification on : Friday, July 8, 2022 - 10:06:03 AM
File
12859_2017_Article_1765.pdf
Publication funded by an institution
Identifiers
Citation
Antoine Basset, Patrick Bouthemy, Jérôme Boulanger, François Waharte, Jean Salamero, et al.. An extended model of vesicle fusion at the plasma membrane to estimate protein lateral diffusion from TIRF microscopy images. BMC Bioinformatics, 2017, 18 (1), pp.352. ⟨10.1186/s12859-017-1765-y⟩. ⟨hal-01561310v2⟩
Share
Metrics
Record views
367
Files downloads
144
