Dynamic Simulation of Rigid Bodies: Modelling of Frictional Contact, Impacts in Mechanical Systems, pp.61-144, 2000. ,
DOI : 10.1007/3-540-45501-9_2
Higher order event capturing time-stepping schemes for nonsmooth multibody systems with unilateral constraints and impacts, Applied Numerical Mathematics, vol.62, issue.10, pp.1259-1275, 2012. ,
DOI : 10.1016/j.apnum.2012.06.026
URL : https://hal.archives-ouvertes.fr/inria-00476398
Numerical Methods for Nonsmooth Dynamical Systems: Applications in Mechanics and Electronics, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
Time-stepping for three-dimensional rigid body dynamics, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.183-197, 1999. ,
DOI : 10.1016/S0045-7825(98)00380-6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.45.6008
Half-explicit Runge-Kutta methods with explicit stages for differential-algebraic systems of index 2, BIT Numerical Mathematics, vol.66, issue.13, pp.415-438, 1998. ,
DOI : 10.1007/978-3-642-05221-7
The generalized?? method in industrial multibody simulation, Proc. of Multibody Dynamics. ECCOMAS Thematic conference, 2009. ,
Error analysis of generalized- $$\alpha $$ ?? Lie group time integration methods for constrained mechanical systems, Numerische Mathematik, vol.42, issue.1, pp.149-179, 2015. ,
DOI : 10.1016/S0045-7825(97)00261-2
Order reduction in time integration caused by velocity projection, Journal of Mechanical Science and Technology, vol.60, issue.1-2, pp.2579-2585, 2015. ,
DOI : 10.1007/s11071-009-9579-8
Structure-Preserving Integrators in Nonlinear Structural Dynamics and Flexible Multibody Dynamics chapter A Lie algebra approach to Lie group time integration of constrained systems. CISM Courses and Lectures A preliminary version of this material was published as, 2015. ,
Non-stiff integrators for differential?algebraic systems of index 2, Numerical Algorithms, vol.19, issue.1/4, pp.25-41, 1998. ,
DOI : 10.1023/A:1019123010801
The contact problem in Lagrangian systems subject to bilateral and unilateral constraints, with or without sliding Coulomb???s friction: a tutorial, Multibody System Dynamics, vol.30, issue.2, pp.43-76, 2016. ,
DOI : 10.1007/s11044-013-9352-0
Ein halb-explizites Runge-Kutta Verfahren der Ordnung 5 zur Behandlung von mechanischen Systemen mit Nebenbedingungen, Computing, vol.19, issue.13, pp.191-201, 1992. ,
DOI : 10.1007/978-3-662-09947-6
HEM5 User's guide, 1994. ,
Half-Explicit Runge???Kutta Methods for Differential-Algebraic Systems of Index 2, SIAM Journal on Numerical Analysis, vol.30, issue.2, pp.538-552, 1993. ,
DOI : 10.1137/0730025
Numerical Solution of Initial-Value Problems in Differential-Algebraic Equations, 1989. ,
DOI : 10.1137/1.9781611971224
Simultaneous enforcement of constraints at position and velocity levels in the nonsmooth generalized-<mml:math altimg="si17.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:mi>??</mml:mi></mml:math> scheme, Computer Methods in Applied Mechanics and Engineering, vol.281, pp.131-161, 2014. ,
DOI : 10.1016/j.cma.2014.07.025
Convergence of the generalized-? scheme for constrained mechanical systems, Multibody System Dynamics, vol.18, issue.2, pp.185-202, 2007. ,
The Generalized-?? Scheme as a Linear Multistep Integrator: Toward a General Mechatronic Simulator, Journal of Computational and Nonlinear Dynamics, vol.3, issue.4, p.41007, 2008. ,
DOI : 10.1115/1.2960475
Time integration of the equations of motion in mechanism analysis, Computers & Structures, vol.33, issue.3, pp.801-820, 1989. ,
DOI : 10.1016/0045-7949(89)90255-1
A Time Integration Algorithm for Structural Dynamics With Improved Numerical Dissipation: The Generalized-?? Method, Journal of Applied Mechanics, vol.60, issue.2, pp.371-375, 1993. ,
DOI : 10.1115/1.2900803
Benchmarking optimization software with performance profiles, Mathematical Programming, vol.91, issue.2, pp.201-213, 2002. ,
DOI : 10.1007/s101070100263
URL : http://arxiv.org/pdf/cs/0102001
Convergence Results for a Coordinate Projection Method Applied to Mechanical Systems with Algebraic Constraints, SIAM Journal on Numerical Analysis, vol.30, issue.5, pp.1467-1482, 1993. ,
DOI : 10.1137/0730076
Numerical Methods in Multibody Dynamics. Teubner, 1998. ,
DOI : 10.1007/978-3-663-09828-7
Multibody Dynamics with Unilateral Contacts, 1996. ,
Automatic integration of Euler-Lagrange equations with constraints, Journal of Computational and Applied Mathematics, vol.12, issue.13, pp.77-90, 1985. ,
DOI : 10.1016/0377-0427(85)90008-1
Flexible Multibody Dynamics: a Finite Element Approach, 2001. ,
Set-Valued Force Laws: dynamics of non-smooth systems, 2001. ,
Curve squealing of trains: Measurement, modelling and simulation, Journal of Sound and Vibration, vol.324, issue.1, pp.365-386, 2009. ,
Complementarity problems in multibody systems with planar friction, Archive of Applied Mechanics, vol.63, issue.7, pp.452-463, 1993. ,
Algorithms of Resolution of the Contact Dynamics with Impact and Friction, 2015. ,
Solving Ordinary Differential Equations I, Nonstiff Problems, 2000. ,
DOI : 10.1007/978-3-662-12607-3
Solving Ordinary Differential Equations II, Stiff and Differential-Algebraic Problems, 2002. ,
Implicit Runge-Kutta Integration of the Equations of Multibody Dynamics in Descriptor Form, Mechanics of Structures and Machines, vol.27, issue.3, pp.337-364, 1999. ,
DOI : 10.1016/0096-3003(79)90001-8
A State-Space-Based Implicit Integration Algorithm for Differential-Algebraic Equations of Multibody Dynamics*, Mechanics of Structures and Machines, vol.19, issue.3, pp.311-334, 1997. ,
Improved numerical dissipation for time integration algorithms in structural dynamics, Earthquake Engineering & Structural Dynamics, vol.7, issue.3, pp.283-292, 1977. ,
DOI : 10.2514/8.1722
Comparison of several numerical methods for mechanical systems with impacts, International Journal for Numerical Methods in Engineering, vol.51, issue.9, pp.1101-1132, 2001. ,
DOI : 10.1002/nme.206
URL : https://hal.archives-ouvertes.fr/hal-00814950
Extensions of the HHT-method to differential-algebraic equations in mechanics, Electronic Transactions on Numerical Analysis, vol.26, pp.190-208, 2007. ,
A Second Order Extension of the Generalized????? Method for Constrained Systems in Mechanics ,
DOI : 10.1007/978-1-4020-8829-2_8
The non-smooth contact dynamics method, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.235-257, 1999. ,
DOI : 10.1016/S0045-7825(98)00383-1
URL : https://hal.archives-ouvertes.fr/hal-01390459
Contact mechanics in multibody systems. Mechanism and Machine Theory, pp.665-675, 1999. ,
DOI : 10.1016/s0094-114x(98)00050-0
Energy conservation in Newmark based time integration algorithms, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.44-47, pp.6110-6124, 2006. ,
DOI : 10.1016/j.cma.2005.12.001
Rotordynamics Prediction in Engineering, 1998. ,
Extrapolation integrators for constrained multibody systems, IMPACT Comp. Sci. Eng, vol.3, pp.213-243, 1991. ,
Engstler. MEXX ? Numerical software for the integration of constrained mechanical multibody systems, 1992. ,
Solving constrained mechanical systems by the family of Newmark and ??-methods, ZAMM- Journal of Applied Mathematics and Mechanics/Zeitschrift für Angewandte Mathematik und Mechanik, pp.772-784, 2006. ,
DOI : 10.1002/zamm.200610285
Test set for initial value problem solvers, release 2.4, Technical Report, vol.4, 2008. ,
DOI : 10.1063/1.4912313
Unilateral Contact and Dry Friction in Finite Freedom Dynamics, Nonsmooth Mechanics and Applications, pp.1-82, 1988. ,
DOI : 10.1007/978-3-7091-2624-0_1
Numerical aspects of the sweeping process, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.329-349, 1999. ,
DOI : 10.1016/S0045-7825(98)00387-9
URL : https://hal.archives-ouvertes.fr/hal-01349847
Partitioned half-explicit Runge-Kutta methods for differential-algebraic systems of index 2, Computing, vol.66, issue.1, pp.43-61, 1997. ,
An implicit Runge?Kutta method for integration of differential-algebraic equations of multibody dynamics, Multibody System Dynamics, vol.9, issue.2, pp.121-142, 2003. ,
DOI : 10.1023/A:1022506312444
On the use of the HHT method in the context of index 3 differential algebraic equations of multi-body dynamics, Proc. of the ECCOMAS Conf. on Advances in Computational Multibody Dynamics, 2005. ,
A method of computation for structural dynamics, Proc. ASCE, pp.67-94, 1959. ,
Performance analysis of some methods for solving Euler-Lagrange equations, Applied Mathematics Letters, vol.8, issue.1, pp.77-82, 1995. ,
DOI : 10.1016/0893-9659(94)00114-R
Dynamics of Multibody Systems, 2013. ,
Conservation laws and the numerical solution of ODEs, Computers & Mathematics with Applications, vol.12, issue.5-6, pp.1287-1296, 1986. ,
DOI : 10.1016/0898-1221(86)90253-1
Reliable solution of special event location problems for ODEs, ACM Transactions on Mathematical Software, vol.17, issue.1, 1987. ,
DOI : 10.1145/103147.103149
MBSPACK ? Numerical integration software for constrained mechanical motion, Surveys on Mathematics for Industry, vol.5, pp.169-202, 1995. ,
Computational Flexible Multibody Dynamics: a Differential-Algebraic Approach, 2013. ,
DOI : 10.1007/978-3-642-35158-7
Step size adjustment and extrapolation for time-stepping schemes in non-smooth dynamics, International Journal for Numerical Methods in Engineering, vol.55, issue.2, pp.761747-1781, 2008. ,
DOI : 10.1007/978-3-663-01227-6
URL : https://hal.archives-ouvertes.fr/hal-01352897
Multibody system simulation. Numerical methods, algorithms and software, 1999. ,
