Dynamic Simulation of Rigid Bodies: Modelling of Frictional Contact, Mechanical Systems: Analysis and Modelling, pp.61-144, 2000. ,
DOI : 10.1007/3-540-45501-9_2
Projected event-capturing time-stepping schemes for nonsmooth mechanical systems with unilateral contact and Coulomb???s friction, Computer Methods in Applied Mechanics and Engineering, vol.256, pp.224-250, 2013. ,
DOI : 10.1016/j.cma.2012.12.012
URL : https://hal.inria.fr/hal-00720747/document
Siconos: a software for the modeling, the simulation and the control of nonsmooth dynamical systems, pp.2005-2016 ,
Numerical Methods for Nonsmooth Dynamical Systems. Applications in Mechanics and Electronics, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
Recent Advances in Contact Mechanics of Lecture Notes in Applied and Computational Mechanics, chapter Applications of an existence result for the Coulomb friction problem, 2013. ,
A formulation of the linear discrete Coulomb friction problem via convex optimization, ZAMM-Journal of Applied Mathematics and Mechanics/Zeitschrift für Angewandte Mathematik und Mechanik, pp.155-175, 2011. ,
DOI : 10.1002/(SICI)1099-1484(200005)5:4<305::AID-CFM96>3.0.CO;2-W
URL : https://hal.archives-ouvertes.fr/inria-00495734
An introduction to Siconos, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00162911
Analysis of collocated feedback controllers for four-bar planar mechanisms with joint clearances, Multibody System Dynamics, vol.32, issue.1, pp.101-136, 2016. ,
DOI : 10.1007/s11044-013-9356-9
URL : https://hal.archives-ouvertes.fr/hal-01218531
Modeling of joints with clearance in flexible multibody systems, International Journal of Solids and Structures, vol.39, issue.1, pp.41-63, 2002. ,
DOI : 10.1016/S0020-7683(01)00186-X
Numerical investigation of a flexible slider???crank mechanism with multijoints with clearance, Multibody System Dynamics, vol.27, issue.1, pp.173-199, 2016. ,
DOI : 10.1177/0954406215593773
Nonsmooth Mechanics: Models, Dynamics and Control, 2016. ,
DOI : 10.1007/978-3-319-28664-8
URL : https://hal.archives-ouvertes.fr/hal-01236953
Simultaneous enforcement of constraints at position and velocity levels in the nonsmooth generalized-<mml:math altimg="si17.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:mi>??</mml:mi></mml:math> scheme, Computer Methods in Applied Mechanics and Engineering, vol.281, pp.131-161, 2014. ,
DOI : 10.1016/j.cma.2014.07.025
Modeling 3D revolute joint with clearance and contact stiffness, Nonlinear Dynamics, vol.65, issue.1, pp.531-548, 2011. ,
DOI : 10.1002/nme.1507
Design issues in mechanical tolerance analysis, Manufacturing Review, vol.1, issue.1, pp.50-59, 1988. ,
A survey of research in the application of tolerance analysis to the design of mechanical assemblies, Research in Engineering Design, vol.97, issue.7, pp.23-37, 1991. ,
DOI : 10.1115/1.3438796
Dynamic analysis of a planar slider-crank mechanism with clearance for a high speed and heavy load press system. Mechanism and Machine Theory, pp.81-100, 2016. ,
Worst-case and statistical tolerance analysis based on quantified constraint satisfaction problems and Monte Carlo simulation, Computer-Aided Design, vol.41, issue.1, pp.1-12, 2009. ,
DOI : 10.1016/j.cad.2008.11.003
Une généralisation de l'inégalité de Fenchel et ses applications aux lois constitutives. Comptes Rendus de l'Académie des Sciences, t 314, série II, pp.125-129, 1992. ,
On the Limitations of Predictions of the Dynamic Response of Machines with Clearance Connections, Journal of Mechanical Design, vol.116, issue.3, pp.833-841, 1994. ,
DOI : 10.1115/1.2919457
Mechanical Error Analysis of Spatial Linkages, Journal of Mechanical Design, vol.100, issue.4, pp.732-738, 1978. ,
DOI : 10.1115/1.3454001
The Dynamic Modeling of Flexible Spatial Machine Systems With Clearance Connections, Journal of Mechanisms Transmissions and Automation in Design, vol.109, issue.1, pp.87-94, 1987. ,
DOI : 10.1115/1.3258790
A parametric study on the dynamic response of planar multibody systems with multiple clearance joints, Nonlinear Dynamics, vol.1, issue.1???2, pp.633-653, 2010. ,
DOI : 10.1007/978-1-4757-4067-7
URL : https://hal.archives-ouvertes.fr/hal-00574014
Revolute joints with clearance in multibody systems, Computers & Structures, vol.82, issue.17-19, pp.1359-1369, 2004. ,
DOI : 10.1016/j.compstruc.2004.03.031
Dynamic Analysis for Planar Multibody Mechanical Systems with Lubricated Joints, Multibody System Dynamics, vol.12, issue.1, pp.47-74, 2004. ,
DOI : 10.1023/B:MUBO.0000042901.74498.3a
Modeling and analysis of planar rigid multibody systems with translational clearance joints based on the non-smooth dynamics approach, Multibody System Dynamics, vol.76, issue.11, pp.165-190, 2010. ,
DOI : 10.1007/978-3-7091-2624-0_1
URL : https://hal.archives-ouvertes.fr/hal-01435625
Effect of Tolerance and Clearance in Linkage Design, Journal of Engineering for Industry, vol.91, issue.1, pp.198-202, 1969. ,
DOI : 10.1115/1.3591516
Worst Case Tolerance Analysis with Nonlinear Problems, Journal of Engineering for Industry, vol.110, issue.3, pp.232-235, 1988. ,
DOI : 10.1115/1.3187874
Influence of Contact Geometry on Local Friction Energy and Stiffness of Revolute Joints, Journal of Tribology, vol.134, issue.2, p.21402, 2012. ,
DOI : 10.1115/1.4006248
Modeling planar slider-crank mechanisms with clearance joints in RecurDyn, Multibody System Dynamics, vol.4, issue.2, pp.127-145, 2014. ,
DOI : 10.1016/S0947-3580(98)70113-X
Simulation and experimentation of multibody mechanical systems with clearance revolute joints, Proceedings of World Academy of Science, Engineering and Technology, 2012. ,
Robust tolerance design for function generation mechanisms with joint clearances. Mechanism and Machine Theory, pp.1286-1297, 2010. ,
DOI : 10.1016/j.mechmachtheory.2010.04.003
The non-smooth contact dynamics method, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.235-257, 1999. ,
DOI : 10.1016/S0045-7825(98)00383-1
URL : https://hal.archives-ouvertes.fr/hal-01390459
Dynamics in the Presence of Unilateral Contacts and Dry Friction: A Numerical Approach, Unilateral Problems in Structural Analysis II, number 304 in CISM Courses and Lectures, pp.151-196, 1987. ,
DOI : 10.1007/978-3-7091-2967-8_10
Tolerance design: Choosing optimal tolerance specifications in the design of machined parts, Quality and Reliability Engineering International, vol.22, issue.1, pp.27-35, 1994. ,
DOI : 10.1002/qre.4680100107
Modeling the Spatial Dynamics of Robotic Manipulators with Flexible Links and Joint Clearances, Journal of Mechanical Design, vol.115, issue.4, pp.839-847, 1993. ,
DOI : 10.1115/1.2919277
Process capability indices, Journal of Quality Technology, vol.18, issue.1, pp.41-52, 1986. ,
Process Capability Indices, 1993. ,
DOI : 10.1007/978-1-4899-4465-8
Non-smooth Behaviour of a Linkage Mechanism with Revolute Clearance Joints, New Advances in Mechanisms , Transmissions and Applications, pp.233-241, 2014. ,
DOI : 10.1007/978-94-007-7485-8_29
Modification of the Leuven integrated friction model structure, IEEE Transactions on Automatic Control, vol.47, issue.4, pp.683-687, 2002. ,
DOI : 10.1109/9.995050
Continuous contact force models for impact analysis in multibody systems 43. C. Lemaréchal. Using a MODULOPT minimization code. Unpublished Technical Note, Nonlinear Dynamics INRIA Rocquencourt, vol.5, issue.2, pp.193-207, 1980. ,
Les modules M2QN1 et MQHESS Unpublished Technical Note, INRIA Rocquencourt, 1983. ,
Dynamics and control of a spatial rigid-flexible multibody system with multiple cylindrical clearance joints. Mechanism and Machine Theory, pp.106-129, 2012. ,
The compliance contact model of cylindrical joints with clearances, Acta Mechanica Sinica, vol.21, issue.5, pp.451-458, 2005. ,
DOI : 10.1007/s10409-005-0061-7
An enhanced formulation to model spatial revolute joints with radial and axial clearances. Mechanism and Machine Theory, pp.123-144, 2017. ,
DOI : 10.1016/j.mechmachtheory.2017.05.020
Unilateral Contact and Dry Friction in Finite Freedom Dynamics, Nonsmooth Mechanics and Applications, number 302 in CISM, Courses and lectures, pp.1-82, 1988. ,
Some numerical methods in multibody dynamics: Application to granular materials, Eur. J. Mech /A. Solids, supp, issue.13, pp.93-114, 1994. ,
Numerical aspects of the sweeping process, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.329-349, 1999. ,
DOI : 10.1016/S0045-7825(98)00387-9
URL : https://hal.archives-ouvertes.fr/hal-01349847
Review of statistical approaches to tolerance analysis, Computer-Aided Design, vol.27, issue.1, pp.6-15, 1995. ,
DOI : 10.1016/0010-4485(95)90748-5
Analysis of Joint Clearances in Multibody Systems, Multibody System Dynamics, vol.43, issue.5, pp.401-420, 2005. ,
DOI : 10.1007/s11044-005-3989-2
An enhanced cylindrical contact force model, Multibody System Dynamics, vol.37, issue.1, pp.277-298, 2015. ,
DOI : 10.1016/S0094-114X(02)00033-2
A critical overview of internal and external cylinder contact force models, Nonlinear Dynamics, vol.220, issue.3, pp.681-697, 2011. ,
DOI : 10.1023/B:MUBO.0000049131.77305.d8
URL : https://hal.archives-ouvertes.fr/hal-00624469
PLM development framework for the Python programming language, 2016. ,
Nonlinear vibration analysis of mechanical systems with multiple joint clearances using the method of multiple scales. Mechanism and Machine Theory, pp.495-509, 2016. ,
Tolerance stack analysis methods. Research and Technology Boeing Information & Support Services, pp.1-44, 1995. ,
Using Monte-Carlo variance reduction in statistical tolerance synthesis, Computer-Aided Design, vol.29, issue.1, pp.63-69, 1997. ,
DOI : 10.1016/S0010-4485(96)00050-4
ISO Deliberates Statistical Tolerancing, Geometric Design Tolerancing: Theories, Standards and Applications, pp.77-87, 1998. ,
DOI : 10.1007/978-1-4615-5797-5_5
Numerics of Unilateral Contacts and Friction. ? Modeling and Numerical Time Integration in Non-Smooth Dynamics, Lecture Notes in Applied and Computational Mechanics, vol.47, 2009. ,
A comprehensive model for 3D revolute joints with clearances in mechanical systems, Nonlinear Dynamics, vol.24, issue.1, pp.309-328, 2015. ,
DOI : 10.1007/s11044-010-9192-0
Multibody modelling of linkage mechanisms including friction, clearance and impact, Proceedings of the 10th World Congress on the Theory of Machines and Mechanisms in Oulu, pp.1387-1392, 1999. ,
Essentials of Monte Carlo simulation: Statistical methods for building simulation models, 2012. ,
DOI : 10.1007/978-1-4614-6022-0
Measurements and simulations of a crank and rocker mechanism including friction, clearance and impacts, Proceedings of the IX. International Conference on the Theory of Machines and Mechanisms in Liberec/Czech Republic, pp.763-768, 2004. ,
Introduction to modelling and parameter identification methodology of linkages by measurements and simulation, Proceedings of the 13th World Congress in Mechanism and Machine Science, 2011. ,
Friction modeling and parameter value estimation of mechanisms, The 2nd Joint International Conference on Multibody Systems Dynamics, pp.302-312, 2012. ,
A new model for dry and lubricated cylindrical joints with??clearance in spatial flexible multibody systems, Nonlinear Dynamics, vol.39, issue.4, pp.25-47, 2011. ,
A new elastohydrodynamic lubricated spherical joint model for rigid-flexible multibody dynamics. Mechanism and Machine Theory, pp.210-228, 2017. ,
DOI : 10.1016/j.mechmachtheory.2016.09.006
Coupling dynamics of a geared multibody system supported by ElastoHydroDynamic lubricated cylindrical joints, Multibody System Dynamics, vol.48, issue.2, pp.259-284, 2015. ,
DOI : 10.1299/jsmec.48.224
Tolerances in computer-aided geometric design. The Visual Computer, pp.214-226, 1987. ,
DOI : 10.1007/bf01952828
Modeling joints with clearance and friction in multibody dynamic simulation of automotive differentials, Theoretical and Applied Mechanics Letters, p.13003, 2013. ,
DOI : 10.1063/2.1301303
Modeling of static friction in closed-loop kinematic chains???Uniqueness and parametric sensitivity problems, Multibody System Dynamics, vol.83, issue.4, pp.337-361, 2017. ,
DOI : 10.1007/s11071-015-2485-3
Improved algorithm for tolerance allocation based on Monte Carlo simulation and discrete optimization, Computers & Industrial Engineering, vol.56, issue.4, pp.1402-1413, 2009. ,
DOI : 10.1016/j.cie.2008.09.005
Modeling and control of crank???slider mechanism with multiple clearance joints, Multibody System Dynamics, vol.28, issue.3, pp.143-167, 2016. ,
DOI : 10.1093/acprof:oso/9780198507239.001.0001
Statistical tolerance synthesis using distribution function zones, International Journal of Production Research, vol.37, issue.17, pp.3995-4006, 1999. ,
DOI : 10.1080/002075499189880
Robust design of assembly and machining tolerance allocations, IIE Transactions, vol.30, issue.1, pp.17-29, 1997. ,
DOI : 10.1023/A:1007437427523
A Kriging Model for Dynamics of Mechanical Systems With Revolute Joint Clearances, Journal of Computational and Nonlinear Dynamics, vol.9, issue.3, p.31013, 2014. ,
DOI : 10.1115/1.4026233
