New One Terminal Digital Algorithm for Adaptive Reclosing and Fault Distance Calculation on Transmission Lines, IEEE Trans on Power Delivery, vol.21, issue.3, pp.1231-1237, 2006. ,
A real-time hardware fault detector using an artificial neural network for distance protection, IEEE Transactions on Power Delivery, vol.16, issue.1, pp.75-82, 2001. ,
DOI : 10.1109/61.905596
New Fault-Location Method for a Single Multiterminal Transmission Line Using Synchronized Phasor Measurements, IEEE Trans on Power Delivery Piscataway, vol.21, issue.3, pp.1148-1153, 2006. ,
Accurate Fault Location in the Power Transmission Line Using Support Vector Machine Approach, IEEE Transactions on Power Systems, vol.19, issue.2, pp.979-986, 2004. ,
DOI : 10.1109/TPWRS.2004.825883
