Research on GPS and GIS Applied in Precision Agriculture, 2009. ,
Variable rate irrigation control system integrated with GPS and GIS[J]. Transactions of the CSAE, pp.134-138, 2006. ,
Performance Accuracy of Low-Cost Dynamic Non-Differential GPS on Articulated Trucks, Applied Engineering in Agriculture, vol.23, issue.3, pp.273-279, 2007. ,
DOI : 10.13031/2013.22680
Field vehicle position monitoring system based on GPS and GIS[J]. Transactions of the CSAE, pp.84-146, 2004. ,
Guidance of a Forage Harvester with GPS, Precision Agriculture, pp.281-291, 2000. ,
GPS POSITION LATENCY DETERMINATION AND GROUND SPEED CALIBRATION FOR THE SATLOC AIRSTAR M3, Applied Engineering in Agriculture, vol.21, issue.5, pp.769-776, 2005. ,
DOI : 10.13031/2013.19702
Information Processing System for Precision Agriculture Based on GPS and GIS[J]. Transactions of the CSAE, pp.145-149, 2002. ,
Application test of soybean sowing by variable fertilization seeder in Heilongjiang reclamation areas[J]. Transactions of the CSAE, pp.143-146, 2008. ,
The Arithmetic of DGPS Guidance for Agriculture Machinery Straight Line Operation, pp.50-53, 2006. ,
Agriculture Machinery Operation Guidance System Based on GPS and GIS[J], pp.32-34, 2008. ,
