Pervasive Agricultural Environment Monitoring System Based on Embedded Database
According to space constraints of the traditional agricultural environment monitoring system, a small database called SQLite was transplanted into the ARM and Linux operation which could store and manage the field information. Users can get information anytime and anywhere through the GSM (Global System for Mobile Communications) network and the WSN(Wireless Sensor Network) by this design, instead of inquiring data from the PC(Personal Computer) which was widely used now. Sensors embedded in the environment, information spread in the air and captured by the handheld instruments, which is a typical application of pervasive computing.
Informatique [cs]
