A Scenario-Based Governance Method for Coordination of Service Life Cycles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sietse Overbeek
  • Fonction : Auteur
  • PersonId : 1012794
Marijn Janssen
  • Fonction : Auteur
  • PersonId : 985668
Yao-Hua Tan
  • Fonction : Auteur
  • PersonId : 999555
Most of today’s organizations are still far from profiting from the full potential of web service technology. Organizations invoke each other’s web services, but do hardly synchronize the life cycles of individual web services with each other. When realizing an integrated service this might cause failures and requires a governance method for synchronizing the life cycles among organizations. In this paper, we emphasize that there is a need for such a method and the basis of the method is explained. This consists of the identification of possible life cycle related scenarios when trying to integrate services. The method also provides support to coordinate and track changes in service life cycles. Based on the different scenarios when attempting to integrate services that have different life cycles, coordination to communicate life cycle changes and having clear agreements about expectations are needed for successful service integration.
978-3-642-19997-4_21_Chapter.pdf (99.7 Ko) Télécharger le fichier
hal-01562883 , version 1 (17-07-2017)
Paternité
Sietse Overbeek, Marijn Janssen, Yao-Hua Tan. A Scenario-Based Governance Method for Coordination of Service Life Cycles. 4th Working Conference on Method Engineering (ME), Apr 2011, Lisbon, Portugal. pp.225-230, ⟨10.1007/978-3-642-19997-4_21⟩. ⟨hal-01562883⟩
44 Consultations
54 Téléchargements
