Application of Method Engineering Principles in Practice: Lessons Learned and Prospects for the Future - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
It seems that in IT sector we are all aware that for the development of non-trivial software the use of software methods is very important. They provides as with knowledge and guidance for the development process which otherwise might become too chaotic and out of control. It has been empirically proven that software development companies which have successfully established their software processes are more efficient, produce software of higher quality and have shorter time-to-market period; specifically if they are able to adapt their ways of working to specifics of a particular project.
978-3-642-19997-4_2_Chapter.pdf (14.91 Ko) Télécharger le fichier
hal-01562884 , version 1 (17-07-2017)
Paternité
Marko Bajec. Application of Method Engineering Principles in Practice: Lessons Learned and Prospects for the Future. 4th Working Conference on Method Engineering (ME), Apr 2011, Lisbon, Portugal. pp.2-3, ⟨10.1007/978-3-642-19997-4_2⟩. ⟨hal-01562884⟩
47 Consultations
57 Téléchargements
