Study on Irrigation Regime of Double Cropping of Winter Wheat with Summer Maize
Winter wheat and summer maize were important grain crops in China, and winter wheat-summer maize continuous cropping was the main tillage method in north China. According to field experiment datas, Jensen models of winter wheat and summer maize were established respectively in this article. To pursue the biggest overall efficiency as object function, the partition of the finite water between wheat and maize were optimized, the optimal irrigation scheduling of continuous cropping of the two crops were confirmed in different hydrological years on different incoming water condition. This paper provided an efficient approach for promoting the reasonable use of agricultural water resources and enhancing water use efficiency in north China.
Informatique [cs]
