Fast Discrimination of Nanfeng Mandarin Varieties Based on Near Infrared Spectroscopy Technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The potential of visible and near infrared (Vis/NIR) spectroscopy was investigated for discriminating the varieties of Nanfeng mandarin fruit nondestructively. The spectra were collected by a spectrophotometer in the wavelength range of 600–1040 nm. Relationship between the spectra and Nafeng mandarin varieties was established using principal component analysis (PCA), supervised independent modeling of class analogy (SIMCA) and backward propagation neural network (BPNN). By comparison the best result was obtained by BPNN with recognition rate of 97.5%. The results suggested Vis/NIR spectroscopy combination with BPNN was a new approach to discriminate of the varieties of Nanfeng mandarin fruit nondestructively.
978-3-642-18354-6_72_Chapter.pdf (111.16 Ko) Télécharger le fichier
hal-01563453 , version 1 (17-07-2017)
Paternité
Huamao Zhou, Chao Zhou, Honghui Rao, Yande Liu. Fast Discrimination of Nanfeng Mandarin Varieties Based on Near Infrared Spectroscopy Technique. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.613-619, ⟨10.1007/978-3-642-18354-6_72⟩. ⟨hal-01563453⟩
41 Consultations
65 Téléchargements
