Goal-Driven Workflow Generation Based on AI Planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yinxue Shi
  • Fonction : Auteur
  • PersonId : 1012898
The success of an enterprise heavily depends on its ability to respond to changes in its environment in an effective and dynamic way. To cope with emerging business trends, automatic workflow generation provides a significant competitive advantage .This paper presents a goal-driven workflow generation, which is pattern-oriented and knowledge-based. First, a process pattern is proposed as a vehicle for knowledge representation. Then, a heuristic intelligent planning algorithm is deployed to construct a workflow automatically according to the goal specified by the users and the business context.
978-3-642-18354-6_44_Chapter.pdf (255.67 Ko) Télécharger le fichier
hal-01563469 , version 1 (17-07-2017)
Paternité
Yinxue Shi, Minghao Yang, Ruizhi Sun. Goal-Driven Workflow Generation Based on AI Planning. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.367-374, ⟨10.1007/978-3-642-18354-6_44⟩. ⟨hal-01563469⟩
47 Consultations
111 Téléchargements
