Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : In this work, we propose a Web-based monitoring system using wireless sensor networks (WSNs) to measure plant parameters and environmental factors in greenhouses. To detect and send these variables, e.g. leaf temperature, air humidity, a ZigBee-based WSN collects data, which is transmitted by GPRS modules and the Internet to a central computer, and all information, including the dynamic topology of WSNs, can be published via the Web. The system provides flexible configuration options for sensor nodes and transport downlink commands, i.e. sensors can be added or removed flexibly in a node without changing the hardware interface and data center service software. Also, the variance of the received signal strength indicator and link quality indicator (LQI) under different distributions of the growing plants was considered to estimate the network link quality to ensure reliable data transmission in the WSNs. Experiments show that the system is reliable, flexible, convenient, and provides good real-time and scalability characteristics.
https://hal.inria.fr/hal-01563473 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, July 17, 2017 - 5:00:37 PM Last modification on : Thursday, March 5, 2020 - 5:42:46 PM Long-term archiving on: : Saturday, January 27, 2018 - 2:57:36 AM
yuling Shi, Zhongyi Wang, Xu Liu, Dongjie Zhao, Lan Huang. A Web-Based Monitoring System as a Measurement Tool in Greenhouses Using Wireless Sensor Networks. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.289-297, ⟨10.1007/978-3-642-18354-6_35⟩. ⟨hal-01563473⟩
