The Study on the Organization Approach of Agricultural Model Components Library Based on Topic Map - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Haiyan Jiang
  • Fonction : Auteur
  • PersonId : 1012902
Yan Zhu
Weixin Cao
  • Fonction : Auteur
  • PersonId : 1012903
The definition and representation on the model base’s descriptions are the basis of reuse, integration and management of heterogeneous model resources. The study proposed the organization method of the agriculture model components based on topic maps. On the basis of the meta-modeling techniques and the topic map techniques, the study comprehensively analyzed the agricultural model characteristics, extracted the model component facets and its associated descriptions, and established the agricultural model component library’s description model (DM-AMCL). Then, it hierarchically mapped and annotated the model component semantic and syntactic information by using the topic map. We designed the organization framework of the agriculture model components library on topic maps (TM-AMCL). For example of wheat development model, the XTM document instance is build. The result shows that, converting the agriculture models base to TM-AMCL can provide a unified descriptions and access to data for the intelligent decision support system developers, the managers of agriculture model and the computer system.
978-3-642-18354-6_25_Chapter.pdf (347.72 Ko) Télécharger le fichier
hal-01563476 , version 1 (17-07-2017)
Paternité
Haiyan Jiang, Bing Fu, Mei Zhang, Yan Zhu, Weixin Cao. The Study on the Organization Approach of Agricultural Model Components Library Based on Topic Map. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.186-197, ⟨10.1007/978-3-642-18354-6_25⟩. ⟨hal-01563476⟩
51 Consultations
56 Téléchargements
