Analyse numerique et optimisation: Une introduction à la modelisation mathematique et à la simulation numerique, 2005. ,
A new combined wavelet methodology applied to GPR and ERT data in the Montagnole experiment (French Alps, J. Geophys. Eng, vol.10, pp.1-17, 2013. ,
The Levenberg???Marquardt iteration for numerical inversion of the power density operator, Journal of Inverse and Ill-Posed Problems, vol.21, issue.2, pp.265-280, 2012. ,
DOI : 10.1515/jip-2012-0091
Inverse heat conduction: ill-posed problems, 1985. ,
Développement d'outils numériques pour l'audit énergétique des bâtiments ,
Diagnostic de structures de génie civil : Identification des propriétés spatiales et de la surface d'un défaut, 2014. ,
Inverse model for defect characterisation of externally glued CFRP on reinforced concrete structures: comparative study of square pulsed and pulsed thermography, Quantitative InfraRed Thermography Journal, vol.4, issue.281, pp.84-114, 2014. ,
DOI : 10.2307/1412159
Ground Penetrating Radar, 2004. ,
Infrared thermography system for transport infrastructures survey with inline local atmospheric parameter measurements and offline model for radiation attenuation evaluations, Journal of Applied Remote Sensing, vol.8, issue.1, pp.1-19, 2014. ,
DOI : 10.1117/1.JRS.8.084978
URL : https://hal.archives-ouvertes.fr/hal-01055043
Active infrared thermography applied to defect detection and characterization on asphalt pavement samples: comparison between experiments and numerical simulations, Journal of Modern Optics, vol.37, issue.18, pp.1759-1769, 2010. ,
DOI : 10.1016/0017-9310(87)90099-8
The detection and thermal characterization of the inner structure of the ???Musmeci??? bridge deck by infrared thermography monitoring, Journal of Geophysics and Engineering, vol.10, issue.6, pp.64003-64013, 2013. ,
DOI : 10.1088/1742-2132/10/6/064003
URL : https://hal.archives-ouvertes.fr/hal-01081320
A joint thermal and electromagnetic diagnostics approach Eppelbaum, L.: Geophysical observations at archaeological sites: Estimating informational content, Archaeological Prospection, pp.25-38, 2014. ,
The Finite Element Method in Heat Transfer and Fluid Dynamics, CRC series in computational mechanics and applied analysis, 2010. ,
Multipath Ghosts in Radar Imaging: Physical Insight and Mitigation Strategies, IEEE Journal of Selected Topics in Applied Earth Observations and Remote Sensing, vol.8, pp.1078-1086, 2015. ,
DOI : 10.1109/JSTARS.2014.2363233
Modelling ground penetrating radar by GprMax, Construction and Building Materials, vol.19, issue.10, pp.755-762, 2005. ,
DOI : 10.1016/j.conbuildmat.2005.06.007
The regularizing Levenberg-Marquardt scheme is of optimal order, Journal of Integral Equations and Applications, vol.22, issue.2, pp.259-283, 2010. ,
DOI : 10.1216/JIE-2010-22-2-259
On the local minima in phase reconstruction algorithms, Radio Science, vol.5, issue.7, pp.1887-189910, 1996. ,
DOI : 10.1007/978-94-011-3436-1
Role of support information and zero locations in phase retrieval by a quadratic approach, Journal of the Optical Society of America A, vol.16, issue.7, pp.1845-1856, 1999. ,
DOI : 10.1364/JOSAA.16.001845
A general optimization method using adjoint equation for solving multidimensional inverse heat conduction, International Journal of Heat and Mass Transfer, vol.34, issue.11, pp.2911-2919, 1991. ,
DOI : 10.1016/0017-9310(91)90251-9
Analysis of the distorted born approximation for subsurface reconstruction: truncation and uncertainties effects, IEEE Transactions on Geoscience and Remote Sensing, vol.41, issue.1, pp.66-74, 2003. ,
DOI : 10.1109/TGRS.2002.806999
A method for the solution of sertains problems to least squares, Appl. Math, vol.2, pp.164-168, 1944. ,
Optimal Control of Systems Governed by Partial Differential Equations, Grundlehren Der Mathematishen Wissenschaften, vol.170, 1971. ,
DOI : 10.1007/978-3-642-65024-6
GPR and IRT tests in two historical buildings in Gravina in Puglia, Geosci. Instrum. Method. Data Syst, vol.55194, pp.541-55010, 2016. ,
Identification rapide de la température dans les structures de génie civil, 2008. ,
Fast three-dimensional temperature reconstruction, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.49-52, pp.3169-3178, 2010. ,
DOI : 10.1016/j.cma.2010.06.022
URL : https://hal.archives-ouvertes.fr/hal-01054135
On-site building walls characterization , Numer. Heat Tr. A-Appl, pp.179-200, 2013. ,
DOI : 10.1080/10407782.2013.730422
Inverse Heat Transfer: Fundamentals and Applications, Applied Mechanics Reviews, vol.55, issue.1, 2000. ,
DOI : 10.1115/1.1445337
Introduction to Ground Penetrating Radar: Inverse Scattering and Data Processing, Series on Electromagnetic Wave Theory ,
DOI : 10.1002/9781118835647
A Microwave Tomography Approach for a Differential Configuration in GPR Prospecting, IEEE Transactions on Antennas and Propagation, vol.54, issue.11, pp.3541-3548, 2006. ,
DOI : 10.1109/TAP.2006.882161
The role of the measurement configuration in inverse scattering from buried objects under the Born approximation, IEEE Transactions on Antennas and Propagation, vol.53, issue.6, pp.1875-1887, 2005. ,
DOI : 10.1109/TAP.2005.848468
Application of ground-penetrating radar technique to evaluate the waterfront location in hardened concrete, Geosci. Instrum. Method. Data Syst, vol.55194, pp.567-57410, 2016. ,
A linear inverse scattering algorithm for realistic GPR applications, Near Surface Geophysics, vol.5, issue.9, pp.29-41, 2007. ,
DOI : 10.3997/1873-0604.2006016
Localization of the Interfaces of a Slab Hidden Behind a Wall, IEEE Transactions on Geoscience and Remote Sensing, vol.45, issue.8, pp.2471-2482, 2007. ,
DOI : 10.1109/TGRS.2007.900994
A strategy for the determination of the dielectric permittivity of a lossy soil exploiting GPR surface measurements and a cooperative target, Journal of Applied Geophysics, vol.67, issue.4, pp.288-295, 2009. ,
DOI : 10.1016/j.jappgeo.2008.09.007
Sparse Reconstruction From GPR Data With Applications to Rebar Detection, IEEE Transactions on Instrumentation and Measurement, vol.60, issue.3, pp.1070-1079, 2011. ,
DOI : 10.1109/TIM.2010.2078310
