Abstract : The coordinate measuring machine systems (CMMS) are widely used for part inspections in manufacturing plants, which mostly include bridge CMMS and horizontal CMMS driven by motor and portable CMMS operated manually. Wire-driven parallel kinematic manipulators (PKMs) have advantages of flexibility, accuracy and large workspace. This paper investigates the feasibility of the coordinate measuring system based on wire-driven PKM. The forward and inverse position solutions are obtained by MATLAB simulation through the kinematic analysis of the manipulator. The controllable workspace with tension conditions and stiffness conditions are obtained by means of the static analysis. Analysis results show that the manipulator have high precision, high speed and large workspace, these advantages just meet the measure requirements of coordinate measuring systems. Finally, a primary experiment is presented to show that the measuring platform of this manipulator can move smoothly and its measurement error is relatively low. The feasibility of taking the wire-driven PKM as coordinate measuring system has been validated by theoretical and experimental study. This research maybe lays a foundation for the further application of wire-driven PKM in the field of coordinate measuring.
https://hal.inria.fr/hal-01564811 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, July 19, 2017 - 11:23:14 AM Last modification on : Thursday, March 5, 2020 - 5:42:48 PM
Ji-Hui Zhou, Qing-Song Cao, Fa-Xiong Sun, Lan Bi. Feasibility of Coordinate Measuring System Based on Wire Driven Robot. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.450-459, ⟨10.1007/978-3-642-18369-0_53⟩. ⟨hal-01564811⟩
