Abstract : Brake beam is one of the important components working in railway vehicles braking process, which directly affects the security and stability of the high-speed running railway vehicles. Through the research of the cutting and welding technology for the 209T straight plate type brake beam, this paper presents an advanced maintenance method, and designs an automatic cutting and welding machine for the brake beam-axle, then studies the basic structure and working principle for the machine in detail. The automatic cutting and welding machine has been operating properly since been used in the maintenance workshop. What is more, the maintenance of each brake beam only spends about 15 minutes, so this advanced maintenance method can improve the efficiency of the maintenance appropriately, and ensure the reliability of maintenance quality.
https://hal.inria.fr/hal-01564815 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, July 19, 2017 - 11:23:17 AM Last modification on : Thursday, March 5, 2020 - 5:42:48 PM
Leping Liu, Mingdong Zhong, Qizheng Dong. Design of Automatic Cutting and Welding Machine for Brake Beam-Axle. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.167-176, ⟨10.1007/978-3-642-18369-0_18⟩. ⟨hal-01564815⟩
