Modeling and Analysis of Pollution-Free Agricultural Regulatory Based on Petri-Net - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fang Wang
  • Fonction : Auteur
  • PersonId : 772483
  • IdRef : 192407368
Qingling Duan
  • Fonction : Auteur
  • PersonId : 1013065
To carry out pollution-free agricultural products certification work is the important issue of people’s daily lives. It is of great significance to construct the pollution-free agricultural regulatory system (PFARS) and achieve the office automation of the certification business. However, the PFARS contains much more steps in dispersion areas that it is very complex for business processes of E-PFAPC. In this paper, we not only provide the method of modeling the PFARS with Petri Net, but also provide the improved method to analysis the Performance of the constructed workflow model. The model for the PFARS provides a more simply process management than original work method. The provided workflow model analysis method can effectively verify the performance of building model. The results show that the PFARS system constructed by the workflow model can implement the business run automatically and own prefect performance.
978-3-642-18369-0_82_Chapter.pdf (366.41 Ko) Télécharger le fichier
hal-01564818 , version 1 (19-07-2017)
Paternité
Fang Wang, Qingling Duan, Lingzi Zhang, Guo Li. Modeling and Analysis of Pollution-Free Agricultural Regulatory Based on Petri-Net. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.691-700, ⟨10.1007/978-3-642-18369-0_82⟩. ⟨hal-01564818⟩
82 Consultations
83 Téléchargements
