FaroArm offers flexible measurement solution, J. Power Engineering, vol.102, issue.9, pp.67-68, 1998. ,
Error modeling for multi-joint coordinate measuring machine, J. Optics and Precision Engineering, vol.7, issue.2, pp.92-96, 1999. ,
Mathematical Model and error Analysis of the Articulated Arm Flexible CMM, J. Nanotechnology and Precission Engineering, vol.3, issue.4, pp.262-267, 2005. ,
The develop of portable Articulated Arm CMM. D. Research institute of mechanical science, 2007. ,
Mathematical Model and Parameter Calibration of the multi-joint coordinate measuring machine, J. Mechanical processing technology and equipment, issue.6, pp.35-36, 2006. ,
A kinematic notation for lower pair mechanism based on matrices, J. ASME Journal of Applied Mechnics, vol.22, issue.6, pp.215-221, 1955. ,
