CRC Check the FPGA to achieve parallel computation, Computer Technology and Development, issue.2, pp.26-62, 2007. ,
Multifunctional compartment bus controller (MVBC) Research and Design, master's thesis, 2005. ,
FPGA-based realization of CRC encoder. Modern electronic technology, pp.18-22, 2005. ,
Based on the VHDL language, multi-purpose vehicle bus encoder design and analysis. Railway communications signal engineering, pp.9-12, 2008. ,
Manchester coding technology based on FPGA design. Modern electronic technology, pp.55-59, 2007. ,
