Numerical Simulations of Compression Properties of SiC/Al Co-continuous Composites - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mingjuan Zhao
  • Fonction : Auteur
  • PersonId : 1013082
Na Li
  • Fonction : Auteur
  • PersonId : 1013083
Longzhi Zhao
  • Fonction : Auteur
  • PersonId : 1013084
Xiaolan Zhang
  • Fonction : Auteur
  • PersonId : 1013085
The numerical simulations of property of SiC/Al co-continuous composites under compression with ANSYS software were carried out. Based on the simulation results, deformational behavior and distribution of stress and strain fields were analyzed. The effects of compression speed for material property was studied. The results showed that Al matrix and SiC reinforcement exhibit different mechanical behavior, large deformation appears inside Al matrix; the configuration of SiC has relatively great influence on intensity and distribution of stress within composites, its ultimate stress occurs near the interface of composites; when an external force is exerted on the composites, Al matrix and SiC reinforcement restrict each other to prevent from producing the strain; With the increase of loading velocity, the stress of matrix and the strain of reinforcement increase rapidly.
978-3-642-18369-0_57_Chapter.pdf (133.87 Ko) Télécharger le fichier
hal-01564840 , version 1 (19-07-2017)
Paternité
Mingjuan Zhao, Na Li, Longzhi Zhao, Xiaolan Zhang. Numerical Simulations of Compression Properties of SiC/Al Co-continuous Composites. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.480-485, ⟨10.1007/978-3-642-18369-0_57⟩. ⟨hal-01564840⟩
74 Consultations
64 Téléchargements
