The Establishing and Analysis of Stress Model about the Roller Brake Tester and the Flat Brake Tester. Machinery Design & Manufacture, pp.50-52, 2005. ,
The analysis of advantage and disadvantage between the roller brake tester and the platform brake tester. Highways & Transportation in Inner Mongolia, pp.28-30, 1998. ,
Contrastive Analysis of Static Inspection and Dynamic Inspection of Automobile Brake Performance, Journal of Northeast Forestry University, issue.5, pp.3493-94, 2006. ,
Analyze the Key Factors that Influence the Braking Force Test, 2006. ,
