Statistical analysis of sound and vibration signals for monitoring rolling element bearing condition, Applied Acoustics, vol.53, issue.1-3, pp.211-226, 1998. ,
DOI : 10.1016/S0003-682X(97)00018-2
Frequency domain model reduction based on principal component analysis. Mechanical Systems and Signal Processing, pp.41-51, 2010. ,
DOI : 10.1016/j.ymssp.2009.05.005
Principal component analysis and blind source separation of modulated sources for electro-mechanical systems diagnostic, Mechanical Systems and Signal Processing, vol.19, issue.6, pp.1293-1311, 2005. ,
DOI : 10.1016/j.ymssp.2005.08.001
Fault diagnostics of roller bearing using kernel based neighborhood score multi-class support vector machine. Expert System With Application, pp.3090-3098, 2008. ,
Rolling element bearings multi-fault classification based on the wavelet denoising and support vector machine. Mechanical system and signal processing, pp.2933-2945, 2007. ,
A decision based one-against-one method for multi-class support vector machine. Pattern Analysis & Applications, pp.164-175, 2004. ,
DOI : 10.1007/s10044-004-0213-6
Study and evaluation of a multi-class SVM classifier using diminishing learning technique, Neurocomputing, vol.73, issue.10-12, pp.1676-1685, 2010. ,
DOI : 10.1016/j.neucom.2009.11.042
