Research on Fault Diagnosis of Engine by Ant Colony Support Vector Machine, Journal Of Vibration And Shock, vol.28, issue.3, pp.83-86, 2009. ,
Noise Diagnosis Research Based on Wavelet Packet and Fuzzy Cclusters about Connecting Rod Bearing Fault. Transactions of the Chinese Society for Agricultural Machinery, pp.87-91, 2005. ,
Neural Networks Applied for Fault Diagnosis of AC Motors, International Symposium of Information Technology, Vols 1-4, Proceedings, pp.2607-2612, 2008. ,
Fault diagnosis for airplane engines using Bayesian networks and distributed particle swarm optimization, Parallel Computing, vol.33, issue.2, pp.124-143, 2007. ,
DOI : 10.1016/j.parco.2006.11.005
The Nature of Statistical Learning Theory, 1995. ,
Support Vector Method for Function Approximation Regression, Estimation, and Signal Processing, Advances in Neural Information Processing Systems, vol.9, pp.281-287, 1996. ,
A novel and quick SVM-based multi-class classifier, Pattern Recognition, vol.39, issue.11, pp.2258-2264, 2006. ,
DOI : 10.1016/j.patcog.2006.05.034
Fault diagnosis of rotating machinery based on improved wavelet package transform and SVMs ensemble, Mechanical Systems and Signal Processing, pp.688-705, 2007. ,
DOI : 10.1016/j.ymssp.2006.01.007
Support Vector Machines and Its Applications in Machine Fault Diagnosis, Journal Of Vibration And Shock, vol.26, pp.29-35, 2007. ,
Support vector machines-based fault diagnosis for turbo-pump rotor, Mechanical Systems and Signal Processing, vol.20, issue.4, pp.939-952, 2006. ,
DOI : 10.1016/j.ymssp.2005.09.006
A fault diagnosis approach for roller bearing based on IMF envelope spectrum and SVM, Measurement, vol.40, issue.9-10, pp.943-950, 2007. ,
DOI : 10.1016/j.measurement.2006.10.010
Machine Condition Monitoring and Fault Diagnosis Technology, 1991. ,
