Marking Path Optimization Algorithm for Laser Marking and Application. APPLIED LASER, pp.290-293, 2009. ,
EDM Lettering Technology of Large-scale Workpiece's Surface, Journal of Chongqing University, vol.5, pp.14-17, 2003. ,
Design of Print Head of Steel Plate Pin-printer and Analysis on the Priciple of Its Print Sign Forming, METALLURGICAL EQUIPMENT, vol.4, pp.53-56, 2003. ,
GA-based Approach to Optimize Cutters Arrangement on theTurret Post of Turning Center, pp.172-175, 2007. ,
An artificial immune system approach to CNC tool path generation, Journal of Intelligent Manufacturing, vol.4488, issue.5, pp.67-77, 2009. ,
DOI : 10.1007/s10845-008-0104-6
Research on Holes Machining Path Planning Optimization with TSP and GA, pp.30-32, 2007. ,
A hybrid-coded genetic algrithm based optimisation of non-productive paths in CN machining [J].The International Journal of Advanced Manufacturing Technology, pp.163-168, 2002. ,
Approach optimizing tool paths arrangement based on genetic algorithm, Journal of Zhejiang University (Engineering science China, vol.40, pp.2117-2121, 2006. ,
Path optimization on laser drilling based on genetic algorithm, Mechanical?Electrical Engineering Magazine. 24, pp.77-79, 2007. ,
PCB drilling path optimization based on ant-coIony aIgorithm[J]. Mechanical?Electrical Engineering Magazine, pp.56-58, 2007. ,
The Optimization Algorithm of Holes Machining Path With Datum Hole, Machine Tool & Hydraulics. 36, pp.28-32, 2008. ,
Component Placement Process Optimization for Chip Shooter Machine Based on Genetic Algorithm, Journal of XI'AN JiaoTong University. 42, pp.295-299, 2008. ,
Tool Path of Lathe Machine in Flexible Transfer Lines by using Genetic Algorithms, 2007. ,
Path planning on a cuboid using genetic algorithms, Information Sciences, vol.178, pp.3275-3287, 2008. ,
A hybrid approach combining an improved genetic algorithm and optimization strategies for the asymmetric traveling salesman problem, Engineering Applications of Artificial Intelligence, vol.21, issue.8, pp.1370-1380, 2008. ,
DOI : 10.1016/j.engappai.2008.01.003
A new grouping genetic algorithm approach to the multiple traveling salesperson problem, Soft Computing, vol.124, issue.1, pp.95-101, 2009. ,
DOI : 10.1016/j.ejor.2005.04.027
On the tool-path optimization of a milling robot, Computers & Industrial Engineering, vol.43, issue.3, pp.455-472, 2002. ,
DOI : 10.1016/S0360-8352(02)00118-3
CNC Tool-Path Planning for High-Speed High-Resolution Machining Using a New Tool-Path Calculation Algorithm[J], Int J Adv Manuf Technol, vol.20, pp.326-333, 2002. ,
The Domain of Admissible Orientation concept: A new method for five-axis tool path optimisation, Computer-Aided Design, vol.40, issue.9, pp.938-950, 2008. ,
DOI : 10.1016/j.cad.2008.07.002
Application of heuristic and hybrid-GASA algorithms to tool-path optimization problem for minimizing airtime during machining, Engineering Applications of Artificial Intelligence, vol.22, issue.3, pp.389-396, 2009. ,
DOI : 10.1016/j.engappai.2008.10.005
Iso-parametric CNC tool path optimization based on adaptive grid generation, The International Journal of Advanced Manufacturing Technology, vol.33, issue.1, pp.538-548, 2008. ,
DOI : 10.2493/jjspe.59.649
Development of intelligent monitoring and optimization of cutting process for CNC turning, International Journal of Computer Integrated Manufacturing, vol.34, issue.5, pp.473-480, 2006. ,
DOI : 10.1016/0890-6955(92)90024-B
