Study on the Influence of Non-electrical Parameters on Processing Quality of WEDM-HS and Improvement Measures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Guangyao Xiong
  • Fonction : Auteur
  • PersonId : 1013121
Meizhu Zheng
  • Fonction : Auteur
  • PersonId : 1013122
Deying Li
  • Fonction : Auteur
  • PersonId : 1013091
Longzhi Zhao
  • Fonction : Auteur
  • PersonId : 1013084
Yanlin Wang
  • Fonction : Auteur
  • PersonId : 1013123
Minghui Li
  • Fonction : Auteur
  • PersonId : 1013124
The high-speed wire electrical discharge machining (WEDM-HS) machine has been more and more favoured by customers for the low manufacturing cost, the degree of automation and the advantages over the WEDM-LS in price performance ratio. However, the processing quality (the precision of form and position and the surface quality) of WEDM-HS is poorer than that of WEDM-LS, and the processing quality is one of the main technical indicators of WEDM. There are many factors on the processing quality of WEDM-HS, the effects of non-electrical parameters, including the machine precision, the wire-moving system and wire-moving way of the wire electrode and the working solution, on the processing quality of WEDM-HS are discussed, and the corresponding measures of improving the processing quality are put forward, which provide the sufficient basis for further improving the processing quality of WEDM-HS.
978-3-642-18369-0_61_Chapter.pdf (156.11 Ko) Télécharger le fichier
hal-01564876 , version 1 (19-07-2017)
Paternité
Guangyao Xiong, Meizhu Zheng, Deying Li, Longzhi Zhao, Yanlin Wang, et al.. Study on the Influence of Non-electrical Parameters on Processing Quality of WEDM-HS and Improvement Measures. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.514-520, ⟨10.1007/978-3-642-18369-0_61⟩. ⟨hal-01564876⟩
63 Consultations
63 Téléchargements
