The evolution of dislocation density during heat treatment and creep of tempered martensite ferritic steels, Acta Materialia, vol.51, issue.16, pp.4847-4862, 2003. ,
DOI : 10.1016/S1359-6454(03)00324-0
Temperature, stress and microstructure in 10Ni5CrMoV steel plate during air???arc cutting process, Computational Materials Science, vol.38, issue.4, pp.631-641, 2007. ,
DOI : 10.1016/j.commatsci.2006.04.011
Strengthening of tensile steel members and bolted joints using adhesively bonded CFRP plates, Construction and Building Materials, vol.20, issue.1-2, pp.22-33, 2007. ,
DOI : 10.1016/j.conbuildmat.2005.06.042
Effects of surface defects on rolling contact fatigue of 60/40 brass, Wear, vol.225, issue.229, pp.225-229, 1999. ,
DOI : 10.1016/S0043-1648(99)00041-1
Fatigue failure of an offshore condensate recycle line in a natural gas production field, Materials Characterization, vol.54, issue.3, pp.246-253, 2005. ,
DOI : 10.1016/j.matchar.2004.12.013
Failure analysis of disintegrator beaters, Engineering Failure Analysis, vol.13, issue.1, pp.155-162, 2006. ,
DOI : 10.1016/j.engfailanal.2004.10.011
Non-destructive testing handbook, Mechanical engineering publisher, 2002. ,
Localized failure of concrete in compression identified by AE method, Construction and Building Materials, vol.18, issue.3, pp.189-196, 2004. ,
A comparative experimental study on the use of acoustic emission and vibration analysis for bearing defect identification and estimation of defect size. Mechanical Systems and Signal Processing, pp.1537-1571, 2006. ,
A study of metal properties using the method of magnetic memory, Metal Science and Heat Treatment, vol.6, issue.9, pp.401-402, 1997. ,
DOI : 10.1007/BF02469065
Screening of weld quality using the magnetic metal memory effect. Welding in the world, pp.196-198, 1998. ,
A Technique for Monitoring the Bends of Boiler and Steam-Line Tubes Using the Magnetic Memory of Metal, Thermal Engineering, vol.48, issue.4, pp.289-295, 2001. ,
Investigation of metal magnetic memory signals from the surface of low-carbon steel and low-carbon alloyed steel, J.CENT.SOUTH UNIV. TECHNOL, vol.14, issue.1, pp.24-27, 2007. ,
Variation of stress-induced magnetic signals during tensile testing of ferromagnetic steels, NDT&E International, vol.41, pp.184-189, 2008. ,
Ferromagnetic hysteresis and the effective field, IEEE Transactions on Magnetics, vol.38, issue.5, pp.3417-3419, 2002. ,
DOI : 10.1109/TMAG.2002.802714
