Application of Background Information Database in Trend Change of Agricultural Land Area of Guangxi
Guangxi Province is one of the regions more serious desertification. This paper using ENVI image processing system, according to remote sensing image interpretation target mark and image spectral characteristics, found remote sensing interpretation model of the background information of forest, shrub and grass, agricultural land, surface water, towns, roads from TM and ETM data from 1988 to 2008, using supervision, unsupervised, maximum classification of natural law to retrieve background information from simple to complex interpretation of each classification. Meanwhile, using human-computer interaction to refine the results. The output shp format data Vector file of disaggregated data edited in the GIS system, and get the background information on various types of remote sensing data each time. The result showed that agricultural land area showed a decreasing trend, but change is not very significant.
Informatique [cs]
