User Guide for NOLB : Non-Linear Normal Mode Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Normal mode analysis (NMA) is an old and well established technique that has recently found many new applications in the field of structural biology and structural bioinformatics. Here we present a user guide for new computational scheme for nonlinear normal mode analysis that extrapolates a motion computed from instantaneous linear and angular velocities to large amplitudes. The method is available at https://team.inria.fr/nano-d/software/nolb-normal-modes/.
NOLB-Manual.pdf (2.8 Mo) Télécharger le fichier
hal-01565129 , version 1 (19-07-2017)
hal-01565129 , version 2 (13-02-2018)
hal-01565129 , version 3 (26-04-2018)
Copyright (Tous droits réservés)
  • HAL Id : hal-01565129 , version 3
Sergei Grudinin. User Guide for NOLB : Non-Linear Normal Mode Analysis. 2018. ⟨hal-01565129v3⟩
479 Consultations
770 Téléchargements
