User Guide for NOLB : Non-Linear Normal Mode Analysis
Normal mode analysis (NMA) is an old and well established technique that has recently found many new applications in the field of structural biology and structural bioinformatics. Here we present a user guide for new computational scheme for nonlinear normal mode analysis that extrapolates a motion computed from instantaneous linear and angular velocities to large amplitudes. The method is available at https://team.inria.fr/nano-d/software/nolb-normal-modes/.
User Guide for NOLB Nonlinear Normal Mode Analysis.pdf (10.89 Mo)
Télécharger le fichier
