129.991 Mb ============================Doing NMA============================ Memory required for the RTB projection matrix. : 1.27167 Mb Reduced Hessian size, p.10 ,
0.00412211 ====================Writing output PDB files===================== Using output mask. : 2ch7 Using output mask for nonlinear modes s Reading input PDB file s Constructing Hessian, 2.14038 s ================================================================= The first section lists the structural parameters, the number of atoms, chains, and the number of =====================Reading input PDB file====================== Input PDB file................................................... : 5b5e.pdb Number of chains read Number of atoms read, pp.00053540900167521-39 ,
1323.39 Mb ============================Doing NMA============================ Lowest mode frequency. : 0.00156711 Highest mode frequency. : 0.00784686 Frequencies : [ 1]. : 0.000678 s Reading input PDB file. : 0.099499 s Constructing Hessian, 6424422 Memory required for the 29.754 s Writing output PDB files......................................... : 28.5004 s, p.156711 ,
10 A Using outputfilename. : 2ch7_nlb_decoys.pdb ================================================================= =========================== Timing : ============================ ================================================================= Parsing arguments. : 0.000178 s Reading input PDB file. : 0.006173 s Constructing Hessian. : 0.605818 s Writing output Decoy files Total time, 1.53608 s ================================================================= Example 11 In the second example we will generate 100 decoys of a the same system with RMSD distributed linearly from 0 to 10 Å compared to the starting structure. We will also minimize the obtained decoys ,
10 A Using outputfilename, ., p.0 ,
22944 Interaction cutoff distance. : 5 A Memory required for the Hessian matrix. : 4.72632 Mb All-atom Hessian size :. : 3054 x 3054 ============================Doing NMA============================ Memory required for the RTB projection matrix, p.10 ,
0.001994 s Reading input PDB file. : 0.002525 s Aligning input PDB file. : 0.000866 s Superposeing input PDB file. : 4.9e-05 s Constructing Hessian. : 0.05935 s Writing output PDB files Total time :. : 0.096657 s ================================================================= ============================Doing NMA============================ Number of computed modes, ., vol.647954, issue.2 9, pp.682681594634-0760569, 1920. ,
Molecular Vibrations: The Theory of Infrared and Raman Spectra, 1955. ,
Normal Mode Analysis of Biomolecular Structures: Functional Mechanisms of Membrane Proteins, Chemical Reviews, vol.110, issue.3, pp.1463-1497, 2010. ,
DOI : 10.1021/cr900095e
A new approach for determining low-frequency normal modes in macromolecules, Biopolymers, vol.81, issue.6, pp.759-771, 1994. ,
DOI : 10.1299/jsme1958.27.529
Building-block approach for determining low-frequency normal modes of macromolecules, Proteins: Structure, Function, and Genetics, vol.77, issue.1, pp.1-7, 2000. ,
DOI : 10.1016/S0764-4469(97)85008-1
Elastic Network Models for Biomolecular Dynamics: Theory and Application to Membrane Proteins and Viruses, Handbook on Biological Networks, pp.129-158, 2009. ,
NOLB: Nonlinear Rigid Block Normal-Mode Analysis Method, Journal of Chemical Theory and Computation, vol.13, issue.5, pp.2123-2134, 2017. ,
DOI : 10.1021/acs.jctc.7b00197
URL : https://hal.archives-ouvertes.fr/hal-01505843
Dynamics of proteins predicted by molecular dynamics simulations and analytical approaches: Application to ?-amylase inhibitor, Proteins: Structure, Function, and Genetics, vol.7, issue.3, pp.512-524, 2000. ,
DOI : 10.1002/pro.5560070314
Anisotropy of Fluctuation Dynamics of Proteins with an Elastic Network Model, Biophysical Journal, vol.80, issue.1, pp.505-515, 2001. ,
DOI : 10.1016/S0006-3495(01)76033-X
A comparison of neighbor search algorithms for large rigid molecules, Journal of Computational Chemistry, vol.250, issue.13, pp.2865-2877, 2011. ,
DOI : 10.1016/0009-2614(95)01434-9
URL : https://hal.archives-ouvertes.fr/hal-00748053
RapidRMSD: rapid determination of RMSDs corresponding to motions of flexible molecules, Bioinformatics, vol.25, 2018. ,
DOI : 10.1002/jcc.20011
URL : https://hal.archives-ouvertes.fr/hal-01735214
Critical assessment of macromolecular conformational transitions computed via linear and nonlinear normal mode analysis, Unpublished ,
Updates to the Integrated Protein???Protein Interaction Benchmarks: Docking Benchmark Version 5 and Affinity Benchmark Version 2, Journal of Molecular Biology, vol.427, issue.19, pp.3031-3041, 2015. ,
DOI : 10.1016/j.jmb.2015.07.016
Collective protein dynamics and nuclear spin relaxation, The Journal of Chemical Physics, vol.102, issue.8, pp.3396-3403, 1995. ,
DOI : 10.1063/1.448692
21 C Clustering of MD trajectory frames, p.23 ,
