Sensorial Systems and Decision Wireless Monitoring and Remote Control of PV Systems Based on the ZigBee Protocol, 297 V. Katsioulis, E. Karapidakis, M. Hadjinicolaou, and A. Tsikalakis A Linear Approach towards Modeling Human Behavior . . . . . . . . . . . . . . . 305 ,
Nonlinear-Fuzzy Based Design Actuator Fault Diagnosis for the Satellite Attitude Control System, p.315 ,
Dias Motion Patterns: Signal Interpretation towards the Laban Movement Analysis Semantics ,
Fault-Tolerant Systems Survey on Fault-Tolerant Diagnosis and Control Systems Applied to Multi-motor Electric Vehicles, 349 Giovana Almeida, José Vieira, José Marques, and Alberto Cardoso Part, p.359 ,
Rui Esteves Araújo, and Ricardo de Castro Design of Active Holonic Fault-Tolerant Control Systems, p.367 ,
Santos Filho Design of Supervisory Control System for Ventricular Assist Device, p.375 ,
Test and Experimental Validation of a VR Treadmill Walking Compensation Device, p.402 ,
Energy Systems -I Embedded Intelligent Structures for Energy Management in Vehicles, p.421 ,
Paul Borza, and Iuliu Szekely Energy Management System and Controlling Methods for a LDH1250HP Diesel Locomotive Based on, p.429 ,
Ana Maria Pu¸sca¸sPu¸sca¸Pu¸sca¸s, and Paul Nicolae Borza Home Electric Energy Monitoring System: Design and Prototyping, p.437 ,
João Murta Pina, and Mário Ventim Neves Sustainable Housing Techno-Economic Feasibility Application, p.445 ,
Energy Systems -II Study of Spread of Harmonics in an Electric Grid, p.457 ,
Eva González Romera, and María Isabel Milanés Montero Impact of Grid Connected Photovoltaic System in the Power Quality of a Distribution Network, p.466 ,
474 Tiago Fonseca and João F. Martins Weather Monitoring System for Renewable Energy Power Production Correlation, Electrical Machines -I Comparison of Different Modulation Strategies Applied to PMSM Drives under Inverter Fault Conditions, p.493 ,
Marques Cardoso Optimization of Losses in Permanent Magnet Synchronous Motors for Electric Vehicle Application, p.502 ,
Up ?-Power Converter for Energy Harvesting Applications, Using Maximum Power Point Tracking, Based on Fractional Open Circuit Voltage, p.510 ,
and Nuno Paulino Wireless Sensor Network System for Measuring the Magnetic Noise of Inverter-Fed Three-Phase Induction Motors with Squirrel-Cage Rotor, p.518 ,
Ioan Peter, and Razvan Mihai Ionescu Part 17: Electrical Machines -II ,
Anabela Pronto, and Mário Ventim Neves A Fractional Power Disk Shaped Motor with Superconducting ,
João Murta Pina, and Mário Ventim Neves Table of Contents XVII Numerical Design Methodology for an All Superconducting Linear Synchronous Motor, p.553 ,
Electronics -I CMOS Fully Differential Feedforward-Regulated Folded Cascode Amplifier, p.565 ,
Redondo Energy Efficient NDMA Multi-packet Detection with Multiple Power Levels, p.581 ,
Electronics -II Resistive Random Access Memories (RRAMs) Based on Metal Nanoparticles, Mário Macedo, and Paulo Pereira Part, vol.19, p.591 ,
Gomes Design, Synthesis, Characterization and Use of Random Conjugated Copolymers for Optoelectronic, p.596 ,
