Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : This paper shows a methodology for Globally-Asynchronous-Locally-Synchronous (GALS) systems specification and verification. The distributed system is specified by non-autonomous Petri net modules, obtained after the partition of a (global) Petri net model. These modules are represented using IOPT (Input-Output Place-Transition) Petri net models, communicating through dedicated communication channels forming the GALS system under analysis. This set of modules is then automatically translated into Maude code through a MDA approach. As the modules of GALS systems run concurrently, the Maude semantics for concurrent objects is used along with message representation. Finally, as a particular case, the system state space is generated from the Maude specification of the GALS system, allowing property verification.
https://hal.inria.fr/hal-01566548 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, July 21, 2017 - 11:25:13 AM Last modification on : Wednesday, June 1, 2022 - 1:56:02 PM
Filipe Moutinho, Luís Gomes, Paulo Barbosa, João Paulo Barros, Franklin Ramalho, et al.. Petri Net Based Specification and Verification of Globally-Asynchronous-Locally-Synchronous System. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.237-245, ⟨10.1007/978-3-642-19170-1_26⟩. ⟨hal-01566548⟩
