Abstract : In this paper a holistic approach to automated service composition in Service Oriented Architecture is presented. The model described allows to specify both functional and non-functional requirements for the complex service. In order to do so a decomposition of the complex service composition process into three stages is proposed, in which a structure, a scenario and an execution plan of a complex service is built. It is believed that service composition tool based on the proposed model will be able to create complex services satisfying efficiently both functional and nonfunctional requirements.
https://hal.inria.fr/hal-01566564 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, July 21, 2017 - 11:25:26 AM Last modification on : Friday, July 21, 2017 - 11:30:46 AM
Paweł Stelmach, Adam Grzech, Krzysztof Juszczyszyn. A Model for Automated Service Composition System in SOA Environment. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.75-82, ⟨10.1007/978-3-642-19170-1_8⟩. ⟨hal-01566564⟩
