Axial Disc Motor Experimental Analysis Based in Steinmetz Parameters
Abstract : Nowadays an economical and environment crisis is felt in the world due to the increasing fuel prices and high CO2 emissions. This crisis is mostly due to present the transportation system, which uses internal combustion engines. The development and integration of electrical motors with improved electro mechanical characteristics, using high temperature superconductors, can provide a sustainable future replacing the conventional internal combustion motors.An axial type disc motor, with high temperature superconductor (HTS) material has been developed and tested in order to obtain an electrical equivalent circuit based on the experimental results. The tested HTS motor exhibits a conventional hysteresis motor type of behavior, even though the hysteretic phenomena don’t have the same principle. The proposed approach allows the description of the equivalent electrical circuit as a conventional hysteresis motor.
Type de document :
Communication dans un congrès
Luis M. Camarinha-Matos. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. Springer, IFIP Advances in Information and Communication Technology, AICT-349, pp.529-536, 2011, Technological Innovation for Sustainability. 〈10.1007/978-3-642-19170-1_58〉
Liste complète des métadonnées
Littérature citée [14 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01566596
Contributeur : Hal Ifip <>
Soumis le : vendredi 21 juillet 2017 - 11:25:49
Dernière modification le : vendredi 21 juillet 2017 - 11:30:43
Fichier
978-3-642-19170-1_58_Chapter.p...
Fichiers produits par l'(les) auteur(s)
Distributed under a Creative Commons Paternité 4.0 International License
Citation
David Inácio, João Martins, Mário Neves, Alfredo Álvarez, Amadeu Rodrigues. Axial Disc Motor Experimental Analysis Based in Steinmetz Parameters. Luis M. Camarinha-Matos. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. Springer, IFIP Advances in Information and Communication Technology, AICT-349, pp.529-536, 2011, Technological Innovation for Sustainability. 〈10.1007/978-3-642-19170-1_58〉. 〈hal-01566596〉
Métriques
Consultations de la notice
82
Téléchargements de fichiers
27
