New Centrifugal Blood Pump With Dual Impeller and Double Pivot Bearing System: Wear Evaluation in Bearing System, Performance Tests, and Preliminary Hemolysis Tests, Artificial Organs, vol.21, issue.4, pp.329-333, 2008. ,
DOI : 10.1046/j.1525-1594.1998.06098.x
Characteristics of a Blood Pump Combining the Centrifugal and Axial Pumping Principles: The Spiral Pump, Artificial Organs, vol.34, issue.6, pp.605-612, 1996. ,
DOI : 10.1111/j.1525-1594.1996.tb04489.x
A Comparative Study Between Flow Visualization and Computational Fluid Dynamic Analysis for the Sun Medical Centrifugal Blood Pump, Artificial Organs, vol.19, issue.5, pp.458-466, 2004. ,
DOI : 10.1007/978-4-431-65921-1_53
Baylor Gyro Pump: A Completely Seal-less Centrifugal Pump Aiming for Long-Term Circulatory Support, Artificial Organs, vol.54, issue.7, pp.599-604, 1993. ,
DOI : 10.1016/0003-4975(91)91333-Q
In Vitro Study to Estimate Particle Release From a Centrifugal Blood Pump, Artificial Organs, vol.282, issue.5, pp.371-376, 2006. ,
DOI : 10.1016/0043-1648(87)90208-0
Eccentric Inlet Port of the Pivot Bearing Supported Gyro Centrifugal Pump, Artificial Organs, vol.39, issue.3, pp.312-317, 1997. ,
DOI : 10.1111/j.1525-1594.1993.tb00634.x
MINIATURIZED ALL-IN-ONE RPM-CONTROLLABLE ACTUATOR FOR GYRO CENTRIFUGAL BLOOD PUMP, 52nd ASAIO Annual Conference, 2006. ,
DOI : 10.1097/00002480-200603000-00163
Material of the Double Pivot Bearing System in the Gyro C1E3 Centrifugal Pump, Artificial Organs, vol.14, issue.2, pp.143-147, 1997. ,
DOI : 10.1111/j.1525-1594.1993.tb00601.x
Flow Visualization Studies to Improve the Spiral Pump Design, Artificial Organs, vol.18, issue.1, pp.680-685, 1997. ,
DOI : 10.1111/j.1525-1594.1997.tb03722.x
Design and Development Strategy for the Rotary Blood Pump, Artificial Organs, vol.21, issue.7, pp.438-446, 1998. ,
DOI : 10.1161/01.CIR.93.10.1826
