Displacement Measurements with ARPS in T-Beams Load Tests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The measurement of deformations, displacements, strain fields and surface defects in many material tests in Civil Engineering is a very important issue. However, these measurements require complex and expensive equipment and the calibration process is difficult and time consuming. Image processing could be a major improvement, because a simple camera makes the data acquisition and the analysis of the entire area of the material under study without requiring any other equipment like in the traditional method. Digital image correlation (DIC) is a method that examines consecutive images, taken during the deformation period, and detects the movements based on a mathematical correlation algorithm. In this paper, block-matching algorithms are used in order to compare the results from image processing and the data obtained with linear voltage displacement transducer (LVDT) sensors during laboratorial load tests of T-beams.
978-3-642-19170-1_31_Chapter.pdf (454.29 Ko) Télécharger le fichier
hal-01566600 , version 1 (21-07-2017)
Paternité
Graça Almeida, Fernando Melicio, Carlos Chastre, José Fonseca. Displacement Measurements with ARPS in T-Beams Load Tests. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.286-293, ⟨10.1007/978-3-642-19170-1_31⟩. ⟨hal-01566600⟩
128 Consultations
73 Téléchargements
