A law of large numbers for branching Markov processes by the ergodicity of ancestral lineages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We are interested in the dynamic of a structured branching population where the trait of each individual moves according to a Markov process. The rate of division of each individual is a function of its trait and when a branching event occurs, the trait of a descendant at birth depends on the trait of the mother. We prove a law of large numbers for the empirical distribution of ancestral trajectories. It ensures that the empirical measure converges to the mean value of the spine which is a time-inhomogeneous Markov process describing the trait of a typical individual along its ancestral lineage. Our approach relies on ergodicity arguments for this time-inhomogeneous Markov process. We apply this technique on the example of a size-structured population with exponential growth in varying environment.
law_large_number_inh23.pdf (276.18 Ko) Télécharger le fichier
hal-01567317 , version 1 (22-07-2017)
hal-01567317 , version 2 (12-03-2018)
hal-01567317 , version 3 (27-03-2019)
Aline Marguet. A law of large numbers for branching Markov processes by the ergodicity of ancestral lineages. 2017. ⟨hal-01567317v1⟩
228 Consultations
201 Téléchargements
