Individual Analysis of Molecular Brain Imaging Data Through Automatic Identification of Abnormality Patterns
We introduce a pipeline for the individual analysis of positron emission tomography (PET) data on large cohorts of patients. This pipeline consists for each individual of generating a subject-specific model of healthy PET appearance and comparing the individual's PET image to the model via a novel regularised Z-score. The resulting voxel-wise Z-score map can be interpreted as a subject-specific abnormality map that summarises the pathology's topographical distribution in the brain. We then propose a strategy to validate the abnormality maps on several PET tracers and automatically detect the underlying pathology by using the abnormality maps as features to feed a linear support vector machine (SVM)-based classifier. We applied the pipeline to a large dataset comprising 298 subjects selected from the ADNI2 database (103 cognitively normal, 105 late MCI and 90 Alzheimer's disease subjects). The high classification accuracy obtained when using the abnormality maps as features demonstrates that the proposed pipeline is able to extract for each individual the signal characteristic of dementia from both FDG and Florbetapir PET data.
Imagerie médicale
