The forward and inverse problems of electrocardiography, IEEE Engineering in Medicine and Biology Magazine, vol.17, issue.5, pp.84-101, 1998. ,
DOI : 10.1109/51.715491
Electrocardiographic Imaging: II. Effect of Torso Inhomogeneities on Noninvasive Reconstruction of Epicardial Potentials, Electrograms, and Isochrones, Journal of Cardiovascular Electrophysiology, vol.12, issue.2, pp.241-252, 2001. ,
DOI : 10.1046/j.1540-8167.2001.00241.x
Predicting tissue conductivity influences on body surface potentialsan efficient approach based on principal component analysis, Biomedical Engineering IEEE Transactions, vol.58, issue.2, pp.256-273, 2011. ,
DOI : 10.1109/tbme.2010.2090151
The inverse problem in electrocardiography: A model study of the effects of geometry and conductivity parameters on the reconstruction of epicardial potentials, IEEE TRANS- ACTIONS ON BIOMEDICAL ENGINEERING, vol.33, issue.7, pp.667-676, 1986. ,
The effect of torso inhomogeneities on body surface potentials quantified using ???tailored??? geometry, Journal of Electrocardiology, vol.22, issue.1, pp.53-72, 1989. ,
DOI : 10.1016/0022-0736(89)90023-X
Physical Properties of Tissue: A Comprehensive Reference Book, 1990. ,
The electric resistivity of human tissues (100 Hz-10 MHz): a meta-analysis of review studies, Physiological Measurement, vol.20, issue.4, pp.1-11, 1999. ,
DOI : 10.1088/0967-3334/20/4/201
The dielectric properties of biological tissues: II. Measurements in the frequency range 10 Hz to 20 GHz, Physics in Medicine and Biology, vol.41, issue.11, pp.22-51, 1996. ,
DOI : 10.1088/0031-9155/41/11/002
Monte Carlo Sensitivity Analysis of Input-Output Models, The Review of Economics and Statistics, vol.70, issue.4, pp.708-712, 1988. ,
DOI : 10.2307/1935838
Parameter sensitivity and uncertainty of the forest carbon flux model FORUG: a Monte Carlo analysis, Tree Physiology, vol.26, issue.6, pp.807-817, 2006. ,
DOI : 10.1093/treephys/26.6.807
On using perturbation analysis to do sensitivity analysis: derivatives vs. differences, Proceedings of the 28th IEEE Conference on Decision and Control, pp.2018-2023, 1989. ,
DOI : 10.1109/CDC.1989.70519
A review of techniques for parameter sensitivity analysis of environmental models, Environmental Monitoring and Assessment, vol.64, issue.2, pp.135-154, 1994. ,
DOI : 10.2172/7091452
Galerkin Finite Element Approximations of Stochastic Elliptic Partial Differential Equations, SIAM Journal on Numerical Analysis, vol.42, issue.2, pp.800-825, 2005. ,
DOI : 10.1137/S0036142902418680
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.144.7627
Solving elliptic boundary value problems with uncertain coefficients by the finite element method: the stochastic formulation, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.12-16, pp.1251-1294, 2005. ,
DOI : 10.1016/j.cma.2004.02.026
A stochastic projection method for fluid flow: Ii. random process, pp.9-44, 2002. ,
Computational aspects of the stochastic finite element method, Computing and Visualization in Science, vol.191, issue.2, pp.3-15, 2007. ,
DOI : 10.1080/17442500008834254
On elliptic partial differential equations with random coefficients, Babes- Bolyai Math, vol.56, issue.2, pp.473-487, 2011. ,
The Homogeneous Chaos, American Journal of Mathematics, vol.60, issue.4, pp.897-936, 1938. ,
DOI : 10.2307/2371268
Modeling uncertainty in flow simulations via generalized polynomial chaos, Journal of Computational Physics, vol.187, issue.1, pp.137-167, 2003. ,
DOI : 10.1016/S0021-9991(03)00092-5
Stochastic Finite Element Method for Torso Conductivity Uncertainties Quantification in Electrocardiography Inverse Problem, Mathematical Modelling of Natural Phenomena, vol.11, issue.2, pp.2016-2017 ,
DOI : 10.1051/mmnp/201611201
URL : https://hal.archives-ouvertes.fr/hal-01289144
Optimal control with sto chastic pde constrai nts and uncertain controls, Computer Methods in Applied Mechanics and Engineering, vol.213, pp.152-167, 2012. ,
DOI : 10.1016/j.cma.2011.11.026
URL : http://arxiv.org/abs/1107.3944
Stochastic Collocation for Optimal Control Problems with Stochastic PDE Constraints, SIAM Journal on Control and Optimization, vol.50, issue.5, pp.2659-2682, 2012. ,
DOI : 10.1137/110835438
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.303.6072
Stochastic inverse heat conduction using a spectral approach, Int. J. Numer. Meth. Engng, vol.60, issue.7, pp.1-24, 2004. ,
Finite element approximations of stochastic optimal control problems constrained by stochastic elliptic PDEs, Journal of Mathematical Analysis and Applications, vol.384, issue.1, pp.87-103, 2011. ,
DOI : 10.1016/j.jmaa.2010.07.036
An efficient monte carlo method for optimal control problems with uncertainty, Computational Optimization and Applications, vol.26, issue.3, pp.219-230, 2003. ,
DOI : 10.1023/A:1026079021836
Numerical solutions for optimal control problems under spde constraints, Tech. rep, 2006. ,
DOI : 10.21236/ada480192
Bayesian state and parameter estimation of uncertain dynamical systems, Probabilistic Engineering Mechanics, vol.21, issue.1, pp.81-96, 2006. ,
DOI : 10.1016/j.probengmech.2005.08.003
A Bayesian approach to multiscale inverse problems using the sequential Monte Carlo method, Inverse Problems, vol.27, issue.10 ,
DOI : 10.1088/0266-5611/27/10/105004
Missing boundary data reconstruction via an approximate optimal control, Inverse Problems and Imaging, vol.2, issue.4, pp.411-426, 2008. ,
DOI : 10.3934/ipi.2008.2.411
Application of Stochastic Finite Element Methods to Study the Sensitivity of ECG Forward Modeling to Organ Conductivity, IEEE Transactions on Biomedical Engineering, vol.55, issue.1, pp.31-40, 2008. ,
DOI : 10.1109/TBME.2007.900563
Decoupled time-marching schemes in computational cardiac electrophysiology and ECG numerical simulation, Mathematical Biosciences, vol.226, issue.1, pp.58-75, 2010. ,
DOI : 10.1016/j.mbs.2010.04.003
Eléments finis stochastiques: approches intrusive et non intrusive pour des analyses de fiabilité, 2005. ,
A scalable framework for the solution of stochastic inverse problems using a sparse grid collocation approach, Journal of Computational Physics, vol.227, issue.9, pp.4697-4735, 2008. ,
DOI : 10.1016/j.jcp.2008.01.019
