Journal articles
The relation between local repolarization and T-wave morphology in heart failure patients
Abstract : Background: Both duration and morphology of the T-wave are regarded important parameters describing repo-larization of the ventricles. Conventionally, T-wave concordance is explained by an inverse relation between the time of depolarization (TD) and repolarization (TR). Little is known about T-wave morphology and TD-TR relations in patients with heart failure. Methods: Electro-anatomic maps were obtained in the left (LV) and right ventricle (RV) and in the coronary sinus (CS) in patients with heart failure with narrow (nQRS, n = 8) and wide QRS complex with (LBBB, n = 15) and without left bundle branch block (non-LBBB, n = 7). TD and TR were determined from the thus acquired electro-grams. Results: In nQRS and non-LBBB patients, TD-TR relations had a slope between 0 and +1, indicating that repolar-ization followed the sequence of depolarization. In LBBB patients, repolarization occurred significantly earlier in the RV than in the LV, fitting with the idea that the discordant T-waves in LBBB are secondary to the abnormal depolarization sequence. However, the slopes of the TD-TR relations in the LV and CS were not significantly different from zero, indicating no major spatial gradient in LV repolarization, despite a considerable gradient in de-polarization. Remarkable was also the large (~100 ms) transseptal gradient in repolarization. Values of the slopes of the TD-TR relation overlapped between the three patient groups, despite a difference in T-wave morphology between LBBB (all discordant) and nQRS patients (all flat/biphasic). Conclusions: Discordant T-waves in LBBB patients are explained by interventricular dispersion in repolarization. T-wave morphology is determined by more factors than the TD-TR relation alone.
Complete list of metadata
Cited literature [35 references]  Display  Hide  Download
https://hal.inria.fr/hal-01567816
Contributor : Mark Potse Connect in order to contact the contributor
Submitted on : Monday, July 24, 2017 - 3:20:28 PM
Last modification on : Friday, July 8, 2022 - 10:06:48 AM
File
Maffessanti-IJC2017-ARI.pdf
Publication funded by an institution
Identifiers
Collections
Citation
Francesco Maffessanti, Joris Wanten, Mark Potse, Francois Regoli, Maria Luce Caputo, et al.. The relation between local repolarization and T-wave morphology in heart failure patients. International Journal of Cardiology, Elsevier, 2017, 241, pp.270 - 276. ⟨10.1016/j.ijcard.2017.02.056⟩. ⟨hal-01567816⟩
Share
Metrics
Record views
91
Files downloads
107
