Boundary data completion: the method of boundary value problem factorization, Inverse Problems, vol.27, issue.5, p.55014, 2011. ,
DOI : 10.1088/0266-5611/27/5/055014
Data completion via an energy error functional, Comptes Rendus M??canique, vol.333, issue.2, pp.171-177, 2005. ,
DOI : 10.1016/j.crme.2004.10.005
URL : https://hal.archives-ouvertes.fr/hal-00086964
On Cauchy's problem: II. Completion, regularization and approximation, Inverse Problems, vol.22, issue.4, p.1307, 2006. ,
DOI : 10.1088/0266-5611/22/4/012
Relating epicardial to body surface potential distributions by means of transfer coefficients based on geometry measurements, Biomedical Engineering IEEE Transactions on, pp.1-11, 1977. ,
Accuracy of lead removal vs linear interpolation in non-invasive electrocardiographic imaging (ECGI), 2015 Computing in Cardiology Conference (CinC), p.2015, 2014. ,
DOI : 10.1109/CIC.2015.7411067
URL : https://hal.archives-ouvertes.fr/hal-01241752
Inverse problem in electrocardiography via factorization method of boundary problems : how reconstruct epicardial potential maps from measurements of the torso ?, International Symposium on Biomedical Imaging (ISBI), p.2015, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00926344
A field-compatible method for interpolating biopotentials, Annals of biomedical engineering, vol.26, issue.1, pp.37-47, 1998. ,
Methods of Solving Reduced Lead Systems for Inverse Electrocardiography, IEEE Transactions on Biomedical Engineering, vol.54, issue.2, pp.339-343, 2007. ,
DOI : 10.1109/TBME.2006.886865
Misfit functional for recovering data in 2d electrocardiography problems. Engineering Analysis with Boundary Elements, pp.492-500, 2010. ,
DOI : 10.1016/j.enganabound.2009.12.006
URL : https://hal.archives-ouvertes.fr/hal-00489550
Interpolation on a triangulated 3d surface, Journal of Computational Physics, vol.80, issue.2, pp.331-343, 1989. ,
Application of the Method of Fundamental Solutions to Potential-based Inverse Electrocardiography, Annals of Biomedical Engineering, vol.46, issue.6, pp.1272-1288, 2006. ,
DOI : 10.1253/jcj.45.1312
A steklov-poincaré variational formulation of the inverse problem in cardiac electrophysiology, CinC-Computing in Cardiology Conference, p.193, 2013. ,
