Implementing Delaunay Triangulations of the Bolza Surface - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1) , (1)
1
The CGAL library offers software packages to compute Delaunay triangulations of the (flat) torus of genus one in two and three dimensions. To the best of our knowledge, there is no available software for the simplest possible extension, i.e., the Bolza surface, a hyperbolic manifold homeomorphic to a torus of genus two. In this paper, we present an implementation based on the theoretical results and the incremental algorithm proposed recently. We describe the representation of the triangulation, we detail the different steps of the algorithm, we study predicates, and report experimental results
LIPIcs-SoCG-2017-44.pdf (1.21 Mo) Télécharger le fichier
slides_SoCG17-iordanov.pdf (4.11 Mo) Télécharger le fichier
Format : Figure, Image
Format : Presentation
Dates and versions
hal-01568002 , version 1 (24-07-2017)
Identifiers
Cite
Iordan Iordanov, Monique Teillaud. Implementing Delaunay Triangulations of the Bolza Surface. 33rd International Symposium on Computational Geometry (SoCG 2017), Jul 2017, Brisbane, Australia. pp.44:1 -- 44:15, ⟨10.4230/LIPIcs.SoCG.2017.44⟩. ⟨hal-01568002⟩
244 View
274 Download
Share
