The influence of spectral characteristics of early reflections on speech intelligibility, The Journal of the Acoustical Society of America, vol.130, issue.2, pp.996-1005, 2011. ,
DOI : 10.1121/1.3609258
Late Reverberant Spectral Variance Estimation Based on a Statistical Model, IEEE Signal Processing Letters, vol.16, issue.9, pp.770-773, 2009. ,
DOI : 10.1109/LSP.2009.2024791
Coherent-to-Diffuse Power Ratio Estimation for Dereverberation, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.23, issue.6, pp.1006-1018, 2015. ,
DOI : 10.1109/TASLP.2015.2418571
Blind speech dereverberation with multi-channel linear prediction based on short time fourier transform representation, 2008 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.85-88, 2008. ,
DOI : 10.1109/ICASSP.2008.4517552
Blind Separation and Dereverberation of Speech Mixtures by Joint Optimization, IEEE Transactions on Audio, Speech, and Language Processing, vol.19, issue.1, pp.69-84, 2011. ,
DOI : 10.1109/TASL.2010.2045183
Probabilistic integration of diffuse noise suppression and dereverberation, 2014 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.5167-5171, 2014. ,
DOI : 10.1109/ICASSP.2014.6854588
An Expectation-Maximization Algorithm for Multimicrophone Speech Dereverberation and Noise Reduction With Coherence Matrix Estimation, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.24, issue.9, pp.1495-1510, 2016. ,
DOI : 10.1109/TASLP.2016.2553457
Subspace methods for the blind identification of multichannel FIR filters, IEEE Transactions on Signal Processing, vol.43, issue.2, pp.516-525, 1995. ,
DOI : 10.1109/78.348133
A least-squares approach to blind channel identification, IEEE Transactions on signal processing, vol.43, issue.12, pp.2982-2993, 1995. ,
Subspace Methods for Multimicrophone Speech Dereverberation, EURASIP Journal on Advances in Signal Processing, vol.2003, issue.11, pp.1074-1090, 2003. ,
DOI : 10.1155/S1110865703305049
URL : https://doi.org/10.1155/s1110865703305049
Robustness of least-squares and subspace methods for blind channel identification/equalization with respect to effective channel undermodeling/overmodeling, IEEE Transactions on Signal Processing, vol.47, issue.6, pp.1636-1645, 1999. ,
DOI : 10.1109/78.765134
Blind channel approximation: effective channel order determination, IEEE Transactions on Signal Processing, vol.47, issue.12, pp.3336-3344, 1999. ,
DOI : 10.1109/78.806077
A class of frequency-domain adaptive approaches to blind multichannel identification, IEEE Transactions on Signal Processing, vol.51, issue.1, pp.11-24, 2003. ,
DOI : 10.1109/TSP.2002.806559
A blind channel identification-based two-stage approach to separation and dereverberation of speech signals in a reverberant environment, IEEE Transactions on Speech and Audio Processing, vol.13, issue.5, pp.882-895, 2005. ,
DOI : 10.1109/TSA.2005.851941
Two-stage blind identification of SIMO systems with common zeros, 14th European Signal Processing Conference, pp.1-5, 2006. ,
Near-Common Zeros in Blind Identification of Simo Acoustic Systems, 2008 Hands-Free Speech Communication and Microphone Arrays, pp.21-24, 2008. ,
DOI : 10.1109/HSCMA.2008.4538678
A Forced Spectral Diversity Algorithm for Speech Dereverberation in the Presence of Near-Common Zeros, IEEE Transactions on Audio, Speech, and Language Processing, vol.20, issue.3, pp.888-899, 2012. ,
DOI : 10.1109/TASL.2011.2168208
Multi-Channel Room Impulse Response Shaping - A Study, 2006 IEEE International Conference on Acoustics Speed and Signal Processing Proceedings, pp.101-104, 2006. ,
DOI : 10.1109/ICASSP.2006.1661222
URL : http://www.isip.uni-luebeck.de/uploads/tx_wapublications/Kallinger-Icassp06.pdf
Room Impulse Response Shortening/Reshaping With Infinity- and $p$-Norm Optimization, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.2, pp.249-259, 2010. ,
DOI : 10.1109/TASL.2009.2025789
URL : http://www.isip.uni-luebeck.de/uploads/tx_wapublications/IEEETASL2010-MMK.pdf
Regularization for Partial Multichannel Equalization for Speech Dereverberation, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.9, pp.1879-1890, 2013. ,
DOI : 10.1109/TASL.2013.2260743
Robust Multichannel Dereverberation using Relaxed Multichannel Least Squares, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.9, pp.1379-1390, 2014. ,
DOI : 10.1109/TASLP.2014.2329632
Inverse Filtering for Speech Dereverberation Less Sensitive to Noise and Room Transfer Function Fluctuations, EURASIP Journal on Advances in Signal Processing, vol.2007, issue.1, pp.1-12, 2007. ,
DOI : 10.1109/89.928915
URL : https://doi.org/10.1155/2007/34013
Joint Dereverberation and Noise Reduction Based on Acoustic Multi-Channel Equalization, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.24, issue.4, pp.680-693, 2016. ,
DOI : 10.1109/TASLP.2016.2518804
A theory of multirate filter banks, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.35, issue.3, pp.356-372, 1987. ,
DOI : 10.1109/TASSP.1987.1165137
Adaptive filtering in subbands with critical sampling: analysis, experiments, and application to acoustic echo cancellation, IEEE Transactions on Signal Processing, vol.40, issue.8, pp.1862-1875, 1992. ,
DOI : 10.1109/78.149989
URL : https://infoscience.epfl.ch/record/33905/files/GilloireV92.pdf
The complex subband decomposition and its application to the decimation of large adaptive filtering problems, IEEE Transactions on Signal Processing, vol.50, issue.11, pp.2730-2743, 2002. ,
DOI : 10.1109/TSP.2002.804068
Subband scale factor ambiguity correction using multiple filterbanks, Proc. International Workshop on Acoustic Echo and Noise Control (IWAENC), pp.1061-1070, 2010. ,
Robust sparsity-promoting acoustic multi-channel equalization for speech dereverberation, 2016 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.166-170, 2016. ,
DOI : 10.1109/ICASSP.2016.7471658
System Identification in the Short-Time Fourier Transform Domain With Crossband Filtering, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.4, pp.1305-1319, 2007. ,
DOI : 10.1109/TASL.2006.889720
Relative Transfer Function Identification Using Convolutive Transfer Function Approximation, IEEE Transactions on Audio, Speech, and Language Processing, vol.17, issue.4, pp.546-555, 2009. ,
DOI : 10.1109/TASL.2008.2009576
Convex optimization, 2004. ,
Non-stationary noise power spectral density estimation based on regional statistics, 2016 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.181-185, 2016. ,
DOI : 10.1109/ICASSP.2016.7471661
URL : https://hal.archives-ouvertes.fr/hal-01250892
Unbiased MMSE-Based Noise Power Estimation With Low Complexity and Low Tracking Delay, IEEE Transactions on Audio, Speech, and Language Processing, vol.20, issue.4, pp.1383-1393, 2012. ,
DOI : 10.1109/TASL.2011.2180896
URL : http://ens.ewi.tudelft.nl/pubs/gerkmann_unbiasedMMSE_TASL2012.pdf
The roomsim user guide (v3. 3), 2004. ,
HRTF measurements of a KEMAR, The Journal of the Acoustical Society of America, vol.97, issue.6, pp.3907-3908, 1995. ,
DOI : 10.1121/1.412407
Getting started with the DARPA TIMIT CD-ROM: An acoustic phonetic continuous speech database, National Institute of Standards and Technology (NIST), vol.107, 1988. ,
Updating the SRMR-CI Metric for Improved Intelligibility Prediction for Cochlear Implant Users, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.12, pp.2197-2206, 2014. ,
DOI : 10.1109/TASLP.2014.2363788
Perceptual evaluation of speech quality (PESQ)-a new method for speech quality assessment of telephone networks and codecs, 2001 IEEE International Conference on Acoustics, Speech, and Signal Processing. Proceedings (Cat. No.01CH37221), pp.749-752, 2001. ,
DOI : 10.1109/ICASSP.2001.941023
Multichannel audio database in various acoustic environments, 2014 14th International Workshop on Acoustic Signal Enhancement (IWAENC), pp.313-317, 2014. ,
DOI : 10.1109/IWAENC.2014.6954309
Statistical and adaptive signal processing: spectral estimation, signal modeling, adaptive filtering, and array processing, 2005. ,
